Cutting 1/0 wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 04:18 PM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Cutting 1/0 wire
I searched a while back on line for methods to cut 1/0 wire. I saw a number of ways from expensive cutters to a good old wood axe. Yesterday was finally time to make my battery cables and I was going to try the hacksaw method or the axe method when.......I came across my pvc pipe cutter. It is a basic home depot model. To my pleasant surprise it actually made a pretty clean cut without mangling (read smashing) the wires . By the third cut, it was noticeably harder to cut through though. Just thought I'd share an inexpensive alternative method using a tool many already have .....
Old 04-27-2011, 04:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Thank's for that bit of info there never thought about using that before. i usually use the hacksaw method .thumbup:
Cole
Old 04-27-2011, 05:25 PM
Joe G's Avatar
Good idea, very resourceful...
Here is my typical weapon for situations like that; The Channellock #911 Cable cutter. In addition to cutting battery cables, I also use it for 'de-wiring' old cars. It'll cut through a bundle of wires an inch round with very little effort. Costs about $16.
Old 04-27-2011, 05:33 PM
302 Z28's Avatar
I have one of those also, great tool
Vince
Old 04-27-2011, 05:47 PM
Wiki Edits: 31
I use bolt cutters when I go to the junkyard.. When I pulled the 460/C6 out of the Lincoln, everything from the A/C lines to any wiring was cut with the bolt cutters... as for pulling rear ends, they cut brake hose and brake cables like butter..
Old 04-27-2011, 07:19 PM
Hwyhogg's Avatar
JOEG & 302, thanks for posting the pic....think I'll pick one of those up for general wire cutting; cause I may have shortened the life of my pvc blade being "resourceful" lol....
Old 04-27-2011, 07:44 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Not really the optimal tool for the job, but no big deal.
Replacement blades can be ordered ... OR you can just sharpen them with a fine file or honing stone.
Ask your local Snap-On dealer about a Lansky sharpener.
My wife swears at me when I sharpen her pairing knives to a razor sharpness.
Old 04-27-2011, 09:20 PM
Hwyhogg's Avatar
I love the info gleaned from this site! Thanks to all!
Old 04-27-2011, 09:57 PM
ogre's Avatar
the 'Duracell Project'
i have the klein version of this cutter
very good for big SO cord too (extension cord)
wire terminal broke off 2-wire alternator bullheimer Electrical 3 10-11-2009 11:22 AM
Shop Converted My 3-wire Alt to 1-wire -- Should I Be Upset? JohnTN Electrical 2 06-28-2006 07:50 PM
Wire Diagram for points,starter,1 wire alt,and distributor plainhavoc Electrical 3 04-12-2006 03:13 AM
One-wire to 3-wire Alternator change nova69 Electrical 2 09-05-2005 08:18 PM
one wire / three wire, alternator hookup 65truck Electrical 1 10-24-2003 04:59 AM
