Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cutting 1/8" aluminum with what tool?
  #16 (permalink)
Old 01-17-2010, 04:26 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by oldred
Don't try to use a cut-off disc on an angle grinder unless the disc is specifically for Aluminum, not sure there is even one out there. I tried it with my 4 1/2' grinder and one of those thin cut-off discs and the darn thing exploded on me! I guess I must be a slow learner because I tried it again and the same thing happened after cutting only a few inches, it wasn't cutting worth a darn anyway so I gave up and used a Milwaukee sawzall.
Anyone else have this happen? I meant to ask about this a couple of weeks ago when that happened but just never got around to it so when I saw this thread I thought I would mention it.
Actually I use the thin disk all the time for cutting aluminum but the disk I use are the Metabo brand. I also cut slow and if cutting steel or aluminum sheet, I first make a shallow cut on my line then go back over it until it's cut through.
