Cutting body filler to make a perfect gap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2011, 02:03 PM
Well I accidentally covered up the gap where the rear quarter meets the rocker panel (67 Mustang), But I'd like it to be a little more straight, anyways.
What's the best way to cut that out, and 'round' it a little bit.. I was going to try a tiny pneumatic recip saw (HF) but decided that it would gouge everything, and not be straight anyways.. Same with a cut off.. Soo.. Any ideas? What do you guys do?
Old 07-12-2011, 02:18 PM
One could rough cut it with a hacksaw blade by hand, you see metal obviously stop. then finish with varying grits of sandpaper.
Old 07-12-2011, 03:19 PM
I had thought about that.. Is that what everyone does?
Old 07-12-2011, 03:41 PM
milo's Avatar
point on positive
Use masking tape to define the line on both sides of it.
Then fold a piece of 80 grit sand paper and use the folded edge to cut...
Old 07-13-2011, 06:46 AM
I have used a square and a scratch awl and then a lite sanding on the edges.
Old 07-13-2011, 08:45 PM
A Dremel tool does a good job if you have a steady hand.
As has been said, use a straight edge and tape to
outline the cut; finish off with sandpaper.
Old 07-16-2011, 10:35 AM
Ive done this before. What you want is a tiny disc on a dremel just like what he said. have a couple beers to calm your hand before doing it. Atleast thats what i do. Cutting body filler is not a cool thing lol
They Didn't make It Perfect? Coodeville Interior 7 04-09-2011 09:56 PM
Best fine-line tape and tips to make a perfect line. smithkustoms Body - Exterior 9 03-24-2010 11:29 AM
Cutting Edge Body eppy Body - Exterior 0 09-02-2007 10:38 AM
Best Body Panel Cutting Tool Ron M Body - Exterior 21 08-16-2004 08:57 AM
Best method to make clean body filler to sheetmetal transition? Sample Body - Exterior 15 08-07-2003 09:40 PM
