cutting doors in a 1934 glass convertible body - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2013, 04:09 AM
I have purchased a 1934 convertible glass body rat rod and need to cut and install doors. Anyone out there been down this road?
fnapres
Old 02-26-2013, 06:26 AM
33Willys77's Avatar
I did a ton of glass work on my car. I chopped and stretched the body, installed the floor, pushed out the firewall, built a steel reinforcement cage inside (all glassed into the outer body skin), put the outter skins of the doors and trunk lid onto the inner panels - and on and on. Yeah, its a huge job and takes a long time. Its not like working with steel were you can just put a tack here and there.
I am not quite sure what you are asking by cutting the doors. If you have a convert, this would make things a little easier. What kind of hinges are you using? Stock style or hidden? Does your body have the inner structure already? If so, most bodies will have the provision for hidden hinges integrated into the structure.
Old 02-26-2013, 09:08 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am wondering what the body is? Only ones I have seen with no doors cut are the T-body cars..How about some pics..??
Sam
Old 02-26-2013, 02:46 PM
Wiki Edits: 27
dragster shell ?
Years ago there were a few companies that made only a shell body for mounting on a drags- bonneville -lakes chassis If that is what you have you will want to build the inner wood-steel structure, glass it to the body before cutting out the doors.
Old 02-26-2013, 04:47 PM
life is a temporary assignment
We need pictures to better help you... If the car has no door jam's, They will need to be built before you cut out the door,,Not all of them,,, But anything that you could glass in before you do any cutting,, Post some pictures of what you have,, Then it will be easier to give you the right answer..
1934 Ford Convertible Top Dan B Interior 0 05-04-2009 08:00 PM
Cutting doors open on race body Mike Britton Interior 10 10-29-2006 03:36 PM
1934 Ford Doors hammer52 Introduce Yourself 1 11-17-2004 10:09 AM
1934 Ford, 3-Window Glass body question kid36 Body - Exterior 0 03-01-2003 06:18 PM
Cutting down glass slider in wa Body - Exterior 1 01-21-2003 12:21 PM
