Cutting A Front Coil Spring - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-30-2009, 05:40 PM
Originally Posted by crownver
...was planning to cut the springs. It also thought I'd try reshaping where I cut them by bending the spring...
A block of wood cut to the right length would make a much easier temporary "spring". Never heat a spring.
  #17 (permalink)
Old 03-30-2009, 10:00 PM
woodz428's Avatar
Troll Hunter
As long as you cut it with a cut off wheel and not a torch it should be fine. I have done several that way. You also want to use a 90* sander to reshape it so it sits in the socket correctly. Cutting a coil will also make it stiffer ( they are torsion bars that are coiled, basicly) the bouncy mentioned may have been from weak shocks not being able to control the stiffer spring. I've never had that result. DO NOT USE A TORCH, and DO NOT QUENCH IT with water, you'll make a weak point that will snap off on the first bounce...I know, that's why I only use a cut off wheel. Fortunately the torched spring was in a race car I was building and snapped with no engine in it,while I was bouncing it...could have been a hell of a ride
  #18 (permalink)
Old 03-30-2009, 10:53 PM
Thanks guys, I just don't see how the spring will sit in the seat. The end of the spring is wound into a tighter circumference and the seat is shaped to match. It would be a good thing if the spring ended up stiffer, as it's a large car spring going into an F100. Like I said, unless it really works well, I'll be getting different springs down the road.
  #19 (permalink)
Old 03-31-2009, 03:03 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by leejoy
My 72 chevy sits a little high in front. Maybe an inch or two. No big deal. A friend of mine who is pretty good working on cars is telling me to cut the front spring and lower the car. I have a big block in the car, so I have big block springs (new), and that's why the car sits a bit high. There is no air conditioning, so the absence of the added weight of an air conditioning system (probably 100 lbs) makes the car sit an inch or two high.
Anyway, I'm doing a front brake conversion soon (drum to disc) and the front springs need to be compressed, and possibly removed anyway, so he says "lets cut the front springs". I told him I heard that is a bad idea, and changes the shape of the end of the spring so it won't seat correctly in the spring pocket. Then, there is always that potential problem of the car sitting to low after they've been cut, and then I'm screwed. He said "I've done it several times and never had a problem"
This is a 600 HP 72 chevy nova - street car.
what do you guys think?
Lee
Take the big block springs out when you do your disc brake job and sell them to someone who needs them. Put small block springs back in the car when you go together with it. The big block less the AC weighs about the same as a small block anyway. If you cut the big block springs, you will change the spring rate and I predict severe unhappiness in your future. Been there, done that. Never again.
  #20 (permalink)
Old 03-31-2009, 04:38 AM
Dont cut or replace
You have a big block.Dont look at your car for a while.That big block will settle the springs after yoy get some miles on it.If you cut or shorten the springs your ride height will go away sooner than you want.Leave it alone go drive it for awhile it will all work its self out.
  #21 (permalink)
Old 03-31-2009, 05:01 AM
if the small block springs were to soft and the big block is too much check out the specs of HD small block springs. I got some for my malibu for around 90 bucks about 5 years ago.
  #22 (permalink)
Old 03-31-2009, 05:40 AM
Springs
You are right.The hd springs will work.But he already has the springs in the car and To keep from doing any more work or spending money the springs he has will work.They just need time to settle down.
need front coil spring help. oldguy829 Suspension - Brakes - Steering 9 07-12-2007 12:53 AM
front spring rate on 36 Buick rat rod henny496 Suspension - Brakes - Steering 3 01-07-2007 09:37 AM
Spring rates for coil over shocks ken demer Suspension - Brakes - Steering 2 08-13-2006 06:27 PM
HELP….HELP info on Moog coil spring, Im running iut of time 406chevelle Suspension - Brakes - Steering 7 04-25-2004 10:39 AM
info on Moog coil spring 406chevelle Suspension - Brakes - Steering 0 04-22-2004 10:26 AM
