cutting the front springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2006, 03:52 PM
i've got a 1980 transam and i just swapped out a pontiac 350 cast iron anchor for a sbc with aluminum heads and manifold. i was wondering if anyone had suggestions as too how much to cut off the springs. This is just going to be a temporary fix until i get (more) money to buy some... i have no idea how much to cut off. thanks!
Old 07-03-2006, 05:21 PM
A 1/4 turn at a time till you get it right. You can always cut more off...you can't add it back.
Old 07-05-2006, 07:53 AM
Kallie49's Avatar
yep, thats the way to do it, 1/4 at a time, reassemble ans check your ride height, its a trial and error process (more trial than error if you do it a 1/4 turn at a time) 2" drop spindles are typically quite reasonable and only take about an hour to install (barring that you dont have to change ball joints)
Old 07-05-2006, 08:51 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
I agree with the 1/4 cut suggestion. Also, make sure the spring is properly seated in the control arms when everything is bolted back together. If the spring isn't seated you will think more needs to be cut and be totally screwed with measurements.
Old 07-05-2006, 10:13 AM
ok thanks you guys, i figured id have to go that route.
Old 07-05-2006, 12:37 PM
Why not just use a set of like year Camaro front coils?
Old 07-05-2006, 12:44 PM
eh i dont wanna spend any money on it for now, im gonna buy new springs and shocks eventually.
Old 07-05-2006, 01:03 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
If you cut them to the right ride height etc and it rides and drives good...I see no need to get new springs later on....shocks maybe.
Cutting Springs 67camarokid Suspension - Brakes - Steering 11 06-01-2006 07:19 PM
Sizing Front coil springs JNJo39 Suspension - Brakes - Steering 4 05-09-2006 03:57 AM
1988 ford ranger front springs not big enough magnum44 Suspension - Brakes - Steering 5 06-16-2005 04:34 AM
Cutting Coil springs MEAN_SBC Suspension - Brakes - Steering 3 07-20-2004 12:49 PM
front springs for my Nova Novaman78 General Rodding Tech 9 10-28-2003 08:39 PM
