Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cutting a fury in half
Old 10-18-2012, 05:51 AM
deadbodyman's Avatar
deadbodyman deadbodyman is online now
Wiki Edits: 11
yeah,you can rent a sawzall at home depot for about 10.00 a day, for a more accurate cut use masking tape as a guide,its quickand ez,,,
Once the flor has been cut through leave the rest and cut from the roof down,,this way as the roof is cut the gap will open insted of closing up and binding the blade...if you find the blade keeps binding you can use wood wedges or cedar door shims (also at HD) to keep the gap open
