Cutting a fury in half - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2012, 12:26 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
Hey guys ... Need some help here I have to cut a Plymouth fury in half long ways and I'm looking for the best way to do it... Now I'm sure you're wondering why well it's because I need to turn it into a wall ornament for a bar my father and I are opening.
Anyway I need it to be almost functional to the point where the doors front and rear open and people can sit in the car... We will be using the driver side I'm partial to taking the body off the frame and cutting it then and then welding a frame from tubing just to support the body against the wall instead of cutting the whole car body and frame together
Any ideas
Old 10-12-2012, 12:34 PM
14" target saw and a couple abrasive blades and you will have it in two halves in no time.
Old 10-12-2012, 02:27 PM
Brace the hell out of it before you cut!
Old 10-12-2012, 02:41 PM
Any idea what a saw like that goes for?
And specifically where should I brace diagonally across the cab?
Old 10-12-2012, 06:07 PM
I have done this sort of thing before and I highly recommend you brace it as well before you cut it. As far as cutting, another method would be using a sawzall. Also, one thing you can think about is not worrying about making these long cuts perfect by running a moulding of some sort (like a threshold moulding available at the hardware store) along the edge, OR sink the edge into the wall by sliding it up against the wall when you are done cutting, then run a line along the edge with a pen then cut along that line removing the drywall behind it and replace it with something thinner or nothing at all depending on what you can put on the inside of the "car". Or simply just run a wood moulding or something on the wall along that line so that it fits up with that edge you cut covered. Painting a mural on the inside of with a view out the "windows". I just thought of that, cool.
Anyway you could still cut with accuracy and not worry about this idea of cutting the wall or something. But if you cut it and it looks good, you may not need to do this. I have never done this exact project but this stuff is coming to my head.
But running a saw across the middle of the hood trunk and roof that I have done and you do need t add bracing first. I cut up a 60 Dodge once for a stereo and adding those braces thru the hood would have been nice.
Old 10-17-2012, 06:34 AM
deadbodyman's Avatar
Wiki Edits: 11
Interesting project...I'd use a sawz all with a long blade...You should cut the floors first and work your way up ,doing the roof last.otherwise the blade will bind making it almost impossable to cut.Think of how you would cut a log laying down ,from the bottom ,right.
Old 10-17-2012, 07:18 AM
HUH? how do you cut a log from the bottom up? I am a little city boy and don't know crap about cutting logs so what am I missing? I am thinking you would want to cut the roof first as it would be supported by the framing and not bind. Where as if you are cutting the floor, who cares if it binds some and the cut looks like crap.
I just recently cut up a Rambler parts car with the sawzall and it went pretty easy!
Old 10-17-2012, 07:43 AM
All with a sawzall in about 45 minutes as I remember.
Old 10-17-2012, 09:02 AM
dinger's Avatar
I'd pull the body off the frame. Remove the doors, hood, trunk. Brace the body in a few spots with some tubing. If you're going to scrap the other half, turn it on it's side, cut through the floor, turn it back on it's base, cut the rest. Cut long, trim away to what is needed. Cut the hood and trunk on a table or saw horses.
I can't see how a half a car is going to provide much seating, it's also going to take up a lot of space. It will look cool though.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 10-17-2012, 09:32 AM
I believe the car is a unibody.
Old 10-17-2012, 01:49 PM
Richiehd's Avatar
JS-70
You can probably rent a swa like that if you have an equipment renatl place nearby.
Get the ear and eye protectors with it!
Old 10-18-2012, 05:51 AM
Wiki Edits: 11
yeah,you can rent a sawzall at home depot for about 10.00 a day, for a more accurate cut use masking tape as a guide,its quickand ez,,,
Once the flor has been cut through leave the rest and cut from the roof down,,this way as the roof is cut the gap will open insted of closing up and binding the blade...if you find the blade keeps binding you can use wood wedges or cedar door shims (also at HD) to keep the gap open
Old 10-19-2012, 10:14 AM
I have already removed much of the things that would be on my way frame with engine and trans ( it's just a front subframe) rear end fuel tank seats inside and I will def brace it I have the car sitting on top of some logs So I can start anywhere I want to start cutting But I believe cutting the floor is best u guys are right I wanna keep everything consistent so I will prob cut it while it is completely assembled and just go right down the middle
Old 10-19-2012, 01:13 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Lots of pics please.
Good luck with it.
Old 10-19-2012, 06:17 PM
1971BB427's Avatar
I agree with Brian. I'd cut from the top down, as the body might buckle when the bottom is cut in half, and then you'll have to fix it before you use it. If you cut the top, hood, and trunk lid first, then all the good body parts will remain good. The undercarriage doesn't matter if it gets a little deformed or not perfect, as it wont show.
glass fuel filter half full of half empty. tomb Hotrodding Basics 4 09-22-2011 11:46 AM
63 Fury Stan Stobie Interior 4 12-25-2008 07:16 PM
electrical fury ajh86 Electrical 2 10-04-2007 07:26 PM
Your All Half Right and Half Wrong zvagabond Hotrodders' Lounge 10 02-09-2006 11:44 PM
Cutting wheels in half? ZeeksChopShop Suspension - Brakes - Steering 8 05-10-2004 10:22 PM
