Cutting a hole for an in-dash stereo
I need to cut a precise opening ( way more precise than the lines in the picture!) for the new stereo I'm putting in my '48 Chevy coupe. I'm thinking of using a mini air cutoff tool to do the job. Can any of you think of a better way to do this? I don't mind buying the right tool for the job. Thanks.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 06-01-2008 at 09:13 AM. |
For that I would probably use my Dremel with a HD cut-off wheel. Some sparks fly but not too bad. I would still tape everything off like Kenny said. Then I would finish the rough edges with a tungsten bit to get it precise, though I would think the frame cover should hide some.
Precision GOOD, sloppy BAD!!! Mini recip saw???? Dang, time for a new tool.............
Cutting a hole for and in dash stereo
A very clean and accurate method of cutting the opening, would be to use Greenlee square punches. They are a little pricey, but they are unbeatable for accurately cutting through sheet metal. This method would require drilling accurate pilot holes for the bolt that connects the cutter with the die.
Another possibility, would be to use a hand nibbler to expand an opening that has been cut just inside the final dimension. Bob |
Not sure of how thick the steel ison a '48 , but I've used straight line sheet metal shears with fantastic results before. Cut the top and bottom lines , then fold the 'tab' back out of your way.
Best of luck with it , whichever method you use. Remember though - Once you hack , you can't go back. Mike |
What about a fine tooth jig saw blade in a jig saw? If you don't want to take a chance of scrathing the paint around the hole lay down some tape for the jig saw to ride against.
Ontario Rodders |
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
The chrome must be removeable?......I know, more damn work........
Ontario Rodders |
THANK YOU!! Poncho, you're brilliant! I just went and checked, and the chrome piece in question is about 16" long and is attached with two spring washers. It will be a piece of cake to get out, and a lot easier to cut the hole. This is why this bulletin board is so great. You really old guys are so smart.
Kenny: I was referring to Poncho who I know is 55 because it shows on his profile, but if the shoe fits................. BTW, in case you didn't notice, I'm 3 years older than Poncho.
...........Spooky, isn't it?..........
Ontario Rodders |
| justdashes/trashes my dash | cozmo | Interior | 22 | 12-28-2012 08:15 AM |
| 70-72 Chevelle Chevelle dash wiring Problem | skeeveman | Electrical | 18 | 01-10-2011 07:44 PM |
| Fiberglass Tutorial | kristkustoms | Interior | 59 | 04-13-2009 07:10 AM |
| Removing 1953 Chevy Suburban dash | Sly's 53 Suburban | Interior | 14 | 07-06-2005 04:28 PM |
| More Problems w/Electric Fan | horvath | Electrical | 13 | 04-12-2004 11:52 AM |
