Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cutting A Hole Through The Paint?
  #19 (permalink)
Old 02-07-2012, 08:18 AM
Low n' 51ow's Avatar
Low n' 51ow Low n' 51ow is offline
It's slow, not to low.....yet.
Last journal entry: 1951 Styleline DeLuxe
Originally Posted by 327 / 350 hp
I don't know about u guys but why wouldn't u use a electricians knock out punch.. Drill a pilot hole first then place punch there and screw together.. Good Luck Jim
327, I do instrumentation and electrical work for a living and even when using a knockout on an elec. panel, it tends to pull the paint from around the edge of the hole. And the enclosure paint is alot thinner than it would be on your ride. Not only that, it can "pull" the metal out around the edges and create an uneven surface that you would have to rework. Probably not a good option if you want to keep from damaging the paint and working surface.......just my two cents.
