Cutting A Hole Through The Paint? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-05-2012, 06:49 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
with the pilot hole and rod you can turn the saw in reverse to cut the paint first.
  #17 (permalink)
Old 02-05-2012, 08:07 PM
327 / 350 hp's Avatar
cutting a hole through paint
I don't know about u guys but why wouldn't u use a electricians knock out punch.. Drill a pilot hole first then place punch there and screw together.. Good Luck Jim
  #18 (permalink)
Old 02-05-2012, 08:17 PM
1971BB427's Avatar
I have never kept pilot blanks. For years I've just predrilled the hole with the holesaw bit, then install the bit reversed in the holesaw so the tip is inside, and the smooth shank is out. Then just drill the hole.
I do mask off close to the hole with paper to keep hot shavings off the paint, but not close enough to drill through the tape. A spray bottle with water works well to cool the blade if needed.
  #19 (permalink)
Old 02-07-2012, 08:18 AM
Low n' 51ow's Avatar
It's slow, not to low.....yet.
Last journal entry: 1951 Styleline DeLuxe
327, I do instrumentation and electrical work for a living and even when using a knockout on an elec. panel, it tends to pull the paint from around the edge of the hole. And the enclosure paint is alot thinner than it would be on your ride. Not only that, it can "pull" the metal out around the edges and create an uneven surface that you would have to rework. Probably not a good option if you want to keep from damaging the paint and working surface.......just my two cents.
  #20 (permalink)
Old 02-07-2012, 08:47 AM
shine's Avatar
SPI Thug
if there is any filler in the area a knock-out punch will crack it and most likely break the bond. not a good thing.
stripped hole by steam hole one 400sbc projectman69 Engine 11 11-06-2011 09:30 AM
2 hole exhaust flange connecting to a 3 hole JLBpontiac350 Engine 0 04-26-2011 02:31 AM
Cutting a hole for an in-dash stereo DanTwoLakes Hotrodding Basics 18 06-02-2008 07:45 PM
Cutting a hole in a hood KB2ROCKET Body - Exterior 8 06-02-2008 05:37 PM
Cutting a hole in a hood. ron2003_h Body - Exterior 8 07-27-2004 12:51 AM
