Cutting holes in dash - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2006, 08:48 AM
Frisco's Avatar
Glad To Be Here
I am getting ready to install gauges in a reproduction steel '32 Ford dash. I have new hole saws in 3 3/8" for speedometer / tach and in 2 1/16" for all other gauges.
Having used hole saws in sheetmetal in the past with what I consider fair results (I am a retired toolmaker) as the hole saws have a tendency to "run out" and end up cutting an oversize hole, I am reluctant to use them.
I would bore them in a milling machine, but no longer have access to one.
I have looked for Greenlee style knock-out punches in the above sizes with no luck.
What do you folks suggest for cutting the holes?
Thanks in advance!
Old 06-09-2006, 09:14 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Can you under cut the hole size and hand file it to the finished diameter? I always use a block of wood under the sheet metal when cutting these type of holes. (I'm sure you know that). When you say run out, are you talking runout of the cutter or that the cutter wobbles around cutting too large of a hole?
Steve
Old 06-09-2006, 10:34 AM
astroracer's Avatar
Get a piece of dense hardwood, a slat from a pallet will work great. Cut a hole in the slat with the intended holesaw and then clamp the slat to the object you want to perforate. Use the existing hole to line up your holesaw and keep it from wandering.
This works very well for me, especially if there is no way to put the item on a drill press or mill. I also use this method to cut larger holes when there is no material for the 1/4" guide bit to run it. I usually don't use the 1/4" bit when cutting holes this way.
Save the template for use later...
Mark
Old 06-09-2006, 10:43 AM
malc's Avatar
Living At The Speed Of Life
I mark out the hole then drill small holes around the inside circumference.
I then knock out the center and file to size, tedious but neat.
I used this method to cut the holes for my Camaros guages.
Old 06-09-2006, 10:52 AM
302 Z28's Avatar
Personally I do not think it will be a problem if the holes are not exactly the size of your hole saw. The gages have a lip on them that will allow for a slight hole size difference. I installed the gages in my fiberglass dash by using a hole saw and I can tell you for a fact the holes are larger than the hole saw. The gages are a snug fit and actually required a little massaging on the hole to get them to slide in
Vince
Old 06-09-2006, 10:54 AM
Wiki Edits: 27
holes in sheet metal
I use and under sized hole saw cause i usually get wobblly holes even with good saws. I use a squeezer type hand nibbler to finish the hole. you can cut any shape with a nibbler. I also have an air nibbler, $20 fron HF. Its NOISY and doesn't wook that good in thicker gauges
Old 06-10-2006, 06:42 AM
Frisco's Avatar
Glad To Be Here
Steve
Yes, I use a block of wood for backup under the sheetmetal. I am talking about the cutter wobbling around cutting too large a hole. This is more prevalent with larger diameter hole saws. Using an undersize hole saw is an option.
Thank you for your suggestion!
Old 06-10-2006, 06:46 AM
Frisco's Avatar
Glad To Be Here
Mark
Now this suggestion sounds excellent! As I read what you have written; you are using a wood pattern of the correct size clamped on top of the sheetmetal to act as a guide for the hole saw. I assume you are also using a wood backup clamped to the back of the sheetmetal.
Thank you for your suggestion! This is what I will do.
Old 06-10-2006, 06:49 AM
Frisco's Avatar
Glad To Be Here
Malc,
I have done this many years in the past. It works OK but feel there is a better way. Thanks for the suggestion.
Old 06-10-2006, 06:54 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That works just fine to guide a hole saw..have done it many times when there was no way to guide the saw by the 1/4 " bit..
Sam
Old 06-10-2006, 06:56 AM
Frisco's Avatar
Glad To Be Here
Vince
I have done the holesaw in fiberglass dash many years ago with no problem. The number of teeth on the larger diameter holesaw (3 3/8") have a tendency to grab and pull the holesaw out of alignment despite the pilot drill when trying to cut the hole in sheetmetal. Doesn't matter if using a drill press, milling machine or hand held. The pilot drill does not offer enough stability to keep the holesaw in alignment.
Astroracer seems to have an excellent solution.
Thank you for your suggestion as well!
Old 06-10-2006, 06:57 AM
Frisco's Avatar
Glad To Be Here
I thought of this as an option. Not sure it could be used for the small diameter holes. Thank you for your suggestion!
Old 06-10-2006, 07:02 AM
Frisco's Avatar
Glad To Be Here
Sam
Your vote of confidence for this method has convinced me that this is the way to go. Thank you for your comments!
Old 06-10-2006, 07:26 AM
Wiki Edits: 3
Actually I think I would like to make a template with all the holes I needed in a piece of 3/4 plywood..then having that as a guide then make my holes..You can pick up all the switch holes as well while you are at it..
Sam
Old 06-10-2006, 08:38 AM
Frisco's Avatar
Glad To Be Here
Sam
Excellent idea!
Since the dash I am going to use is relatively flat, this is a very workable suggestion!
Thanks to all who have replied. I appreciate you all.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 04:14 PM
justdashes/trashes my dash cozmo Interior 25 04-03-2016 08:09 PM
My work in progress custom dash: advice needed. friday General Rodding Tech 6 12-31-2010 01:20 PM
Fiberglass Tutorial kristkustoms Interior 59 04-13-2009 07:10 AM
Mounting fiberglass dash mrmagoo187 Interior 24 11-04-2005 05:43 PM
