Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cutting hood opening for flytrap scoop
Old 01-15-2012, 07:26 AM
shine's Avatar
shine shine is offline
Last journal entry: some progress
if you mean a through the hood scoop i make a cardboard template to locate the hole. first i make the hole then lay it on the car to locate it. mark the cowl line. the see if it clears when you lift it up.
