-   -   Cutting hood opening for flytrap scoop (http://www.hotrodders.com/forum/cutting-hood-opening-flytrap-scoop-212456.html)
MadMacs 01-13-2012 10:47 PM
Hi board members I need some advice to cut an opening in my steel hood for my flytrap scoop. I have a Edelbrock TRX-1 tunnel ram topped off with a pair of Carter 500's on my 1972 Chevy Nova. My scoop is an old school Mr. Gasket biggie. So give me a baseline and we will work up from there. Thx Madmacs.
shine 01-15-2012 07:26 AM
if you mean a through the hood scoop i make a cardboard template to locate the hole. first i make the hole then lay it on the car to locate it. mark the cowl line. the see if it clears when you lift it up.
MadMacs 01-16-2012 01:43 PM
Thanks for the reply, shine. Yeah I am looking to cut a hole in my hood for the flytrap. I did find an excellent web link from car craft
http://www.carcraft.com/howto/ccrp_0...p/viewall.html
to help anyone else out there with the task.
shine 01-16-2012 01:49 PM
do yourself a favor. make the cardboard hood first then see if it matches the measurement. dont ask how i know....... :(
MARTINSR 01-16-2012 01:58 PM
Listen to Shine, the template and trial fitting parts are the fabricators best friends. Time spent on templates is VERY good time spent indeed.
shine 01-16-2012 02:00 PM
and a hell of a lot cheaper than another hood !!!!!!!!!!!!!!!!!!
malc 01-16-2012 02:05 PM
When I did mine, 86 Camaro, I found the motor is offset to the pass. side,
as you can see here.
http://i65.photobucket.com/albums/h2...finished-1.jpg
And here´s the cutting pic., take care....
http://i65.photobucket.com/albums/h2...an/Holecut.jpg
