Cutting hood opening for flytrap scoop - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2012, 10:47 PM
Hi board members I need some advice to cut an opening in my steel hood for my flytrap scoop. I have a Edelbrock TRX-1 tunnel ram topped off with a pair of Carter 500's on my 1972 Chevy Nova. My scoop is an old school Mr. Gasket biggie. So give me a baseline and we will work up from there. Thx Madmacs.
Old 01-15-2012, 07:26 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
if you mean a through the hood scoop i make a cardboard template to locate the hole. first i make the hole then lay it on the car to locate it. mark the cowl line. the see if it clears when you lift it up.
Old 01-16-2012, 01:43 PM
Thanks for the reply, shine. Yeah I am looking to cut a hole in my hood for the flytrap. I did find an excellent web link from car craft
http://www.carcraft.com/howto/ccrp_0...p/viewall.html
to help anyone else out there with the task.
Old 01-16-2012, 01:49 PM
shine's Avatar
SPI Thug
do yourself a favor. make the cardboard hood first then see if it matches the measurement. dont ask how i know.......
Old 01-16-2012, 01:58 PM
Listen to Shine, the template and trial fitting parts are the fabricators best friends. Time spent on templates is VERY good time spent indeed.
Old 01-16-2012, 02:00 PM
shine's Avatar
SPI Thug
and a hell of a lot cheaper than another hood !!!!!!!!!!!!!!!!!!
Old 01-16-2012, 02:05 PM
malc's Avatar
Living At The Speed Of Life
When I did mine, 86 Camaro, I found the motor is offset to the pass. side,
as you can see here.
And here´s the cutting pic., take care....
Hood Scoop? Minor Problem Body - Exterior 1 03-25-2009 03:58 AM
Too small scoop opening? staleg General Rodding Tech 16 12-18-2008 06:39 AM
Fiberglassing a hood scoop on a metal hood Quarter Flash Body - Exterior 11 09-25-2007 06:22 PM
Custom split hood opening ideas? JhnBrackett Body - Exterior 2 06-23-2005 04:22 PM
backward opening hood 34psyco Hotrodders' Lounge 2 11-08-2002 07:47 AM
