Cutting out - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2009, 01:36 PM
Cutting out
hey, thatnks for reading this. i hav a 76 chevy truck it has a small block 400. it ran good until yesterday, every time that i try to take off it cuts out but it doesnt die. it kind of sputters. does anyone know what might be wrong. thanks
Old 01-03-2009, 01:38 PM
re
By the way, when i put it in park and rev it up it sounds fine but when i put it in gear it it does that sputtering thing,lol sorry i dont know what it is.
Old 01-03-2009, 01:44 PM
plug wires
vacuum leak
Old 01-03-2009, 01:47 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
carb or distributer.
Old 01-03-2009, 01:48 PM
re
i checked all the wires and they are tight. but where or are the most common vacuum leaks at
Old 01-03-2009, 01:54 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
spay some starting fluid around the base of the carb or anywhere else you might think its leaking vac and it should rev up
Old 01-03-2009, 02:24 PM
re
ok and if it revs up how do i fix the leak
Old 01-03-2009, 02:34 PM
eloc431962's Avatar
Wiki Edits: 37
depends on where the leak is at where is the leak.
Old 01-03-2009, 02:49 PM
eloc431962's Avatar
Wiki Edits: 37
wherever its leaking you will have to change the gasket on what is leaking is it vacum line or what it is . just trying to help.
Old 01-03-2009, 02:54 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Sounds like a muffler bearing problem from here...
Ok, Ok ... check your fuel delivery. An engine under load requires more fuel. It might act that way if, say, the fuel filter was almost plugged off ... ???
Old 01-03-2009, 03:03 PM
eloc431962's Avatar
Wiki Edits: 37
yea it could be the fuel filter stopping up/or you got some bad gas. makes good sense 66gmc
Old 01-03-2009, 03:10 PM
T-bucket23's Avatar
Wiki Edits: 26
Sounds like a classic accelerator pump issue if it is a carb. More info on the engine is needed. Is it carbed, what kind of distributor etc.
Chet
Old 01-03-2009, 03:46 PM
re
wow thanks guys. ya its carb its a quaderpuke(lol ). it has the points, just the stockdist. i rebuilt the motor and the carb.
Old 01-03-2009, 03:50 PM
re
im savin up to get a better carb but i need this one to get me by, so i rebuilt it and i havnt had a problem with it until yesterday.
Old 01-03-2009, 06:00 PM
T-bucket23's Avatar
Wiki Edits: 26
If you look down the carb while pushing the throttle with the engine off you should see a good shot of fuel. If not you probably have a bad accelerator pump. It is fairly easy to replace. You will probably need to buy a whole rebuild kit to get one.
The other thing I would check it point gap. Should be about .017 - .019 with the point rubbing block on one of the dist cam hight points. If you have or can borrow a dwell meter set it to 28-32 degrees.
The accelerator pump is a common issue with that style carburetor.
Chet
cutting grinding wheel thickness tomthecomic Garage - Tools 9 02-11-2008 11:22 AM
Issues cutting / polishing new clear blacksunshine Body - Exterior 7 11-07-2006 06:05 PM
Cutting, Chopping, Stretching - how to..??? Pickup Guy Body - Exterior 0 05-08-2006 06:33 AM
Crank Cutting BigDawgsEatFirst Engine 11 08-24-2005 08:49 PM
Cutting curved windshield swoodard23 Body - Exterior 16 08-05-2005 10:27 AM
