cutting out when i let off or mid pedel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2012, 02:26 PM
rambler454's Avatar
Last journal entry: 1968 c-10
okay. heres the deal. i got a set of these i put on my 350. now everyone is telling me to drill holes in them for breather and PVC so my motor can breath. okay i fixed that problem but now when i get on it and then let out it cuts out bad. ive tryied 3 carb,timing,intakes i dont know help! p.s. my bottom end is stock std bore. new rings and bearings. but top end is aluminum holly heads edelbrock RPM intake 750 edelbrock. its a 1407 carb. i got headers and a 292 thumper cam. longer pushrods rollerrockers.
Old 04-14-2012, 09:46 PM
DoubleVision's Avatar
What's the timing set at? Has the float level been checked? What's the fuel pressure? Checked it for vacuum leaks?
hard pedel slow stop campracing Suspension - Brakes - Steering 10 12-22-2009 09:09 AM
39 chev PU hanging pedel stea Suspension - Brakes - Steering 6 05-31-2005 12:12 PM
Mid Plate pro70z28 Engine 2 03-26-2005 05:46 PM
Brake pedel weak RickB1B Suspension - Brakes - Steering 21 02-12-2005 06:18 PM
Mid 60's C-10 Posi??? Rogue 64 Transmission - Rearend 1 04-12-2004 06:57 AM
