cutting square aluminum tubes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2009, 06:57 PM
I need to cut some square aluminum tubing, 1 inch x1 inch thinwall. Any suggestions on how to use my chop saw or table saw to get nice square ends ? Will an abrasive disc clog ? Carbide tipped saw blade with lots of teeth work?
Thanks Mike B
Old 10-27-2009, 07:10 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Chop saw will work fine..
Old 10-27-2009, 07:13 PM
540z's Avatar
Brute force and ignorance.....
I'm in the process of building an aluminum boat and recently bought a 10" Chop Saw blade for cutting aluminum and non-ferrous metals at Home Depot. It was about 49 bucks. Be warned when you use it, wear eye and face protection, cause chips go everywhere!
TR
Old 10-27-2009, 07:39 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
You can actually use wood working tools to cut aluminum. A miter saw with a carbide combination blade will do a very good job. I have seen guys run sheets of aluminum through a table saw. Kinda scares me.
Do protect your face and eyes though.
Old 10-27-2009, 07:52 PM
When I ran a alum shop, We would cut alum sheet's with a skill saw all the time..With a good blade..
I PROTECTION IS A MUST !!!!!
Old 10-28-2009, 07:27 AM
cboy's Avatar
Last journal entry: Finished
I use my DeWalt chop saw with a metal abrasive blade to cut aluminum tube without any problems. Incidentally, I also recently cut these 1/8" thick (and approx 16x20 dimensions) aluminum inserts for my upholstery project using a 4 1/2" angle grinder with a normal abrasive cutting blade.
And as others have noted...wear eye protection. I always use a full face mask myself...I don't like collecting metal particles in my fillings.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 10-28-2009, 03:22 PM
Cutting Alum Tubing
Thanks all for the advice, headed out to the shop with safety glasses and a 10 inch abrasive disc..... we shall see what happens..Mike B
Old 10-28-2009, 05:39 PM
cboy's Avatar
Somebody go check on oldcpecdr...he's not in from the shop yet!!!!!!
Old 10-28-2009, 07:31 PM
Worked great !!!
OK project worked out great....thanks for all the help..and the concern C-Boy
Mike B
Old 11-03-2009, 08:04 PM
Project Finished and installed
Thanks for all the suggestions, thought I should post the finished project..the prices I got for signs were RIDICULOUS...so I made up the frames and they came out ok...the acrylic was more of a challenge to cut then the aluminum..
Thanks again ...Mike B
ID:	41729   Click image for larger version
ID:	41730   Click image for larger version
ID:	41731   Click image for larger version
aluminum firewall thoughts (seeking input) toolman1967 Body - Exterior 6 03-12-2008 05:46 PM
Chrome Aluminum versus Polished Aluminum joeford General Rodding Tech 14 02-26-2008 11:18 AM
Aluminum fuel line vs. rubber near engine McDeuce Engine 1 02-16-2004 06:39 PM
Bonding Custom Aluminum Panels To Steel bmech211 Body - Exterior 2 12-16-2003 08:49 PM
Prepping Aluminum Interior for Paint/Clear maxx levell General Rodding Tech 3 08-31-2003 03:53 PM
