Brian |
cutting 2 panels??
NO,i would cut the old panel exactly where you need to cut the new one.maybe draw a line on panel with an AWL,cut a little big,and grind to line,then put either piece of old panel over new panel,tape them together (or C clamp them)again scribe a line with the AWL, cut a little larger,then grind to line.MEASURE A bunch of times,only cut 1 time. we use the 1/32 nd cut off wheel,on a 4 inch elec grinder, HF has discs and elec grinder (not a very good one though)or HD sells some good ones (more expensive though) have fun
http://allshops.org/cgi-bin/communit...9990202483912& The Panel_cut_and_fit.doc gives a pretty good diagam of what he is talking about. I would never have thought about cutting on an angle - but I tried it and it works. Curves are a *****. |
I use a 3" air grinder which I grip with my right hand, and then I support my right hand with my left - somewhat like a golf club grip. It works pretty well for straight cuts but can be a bit tricky on curves. I dont have any clecos yet, so I use small self tapping screws to hold the panel in place while I am cutting. Hope this helps. |
You are right Bob, that is the best way to do it. But when I want to make one of those perfect butts I use offset tin snips for a flawless cut up to the line. I use the cut off disc to rough cut it about a quarter inch from the line then the offset tin snips for perfection.
Brian |
i mark , cut and fit . i keep old speaker magnets to hold the pieces in place while welding.
Actually it's easier just to use an air saw with a 24TPI blade, nice clean cut and curves are no problem. An exact match every time.
The air space should be equal to the metal thickness of the panels Use the butt weld clamps, start at the top-center and work around from there. Metal warping is not a problem IF there is no stress to the panels. DO NOT clamp down the panel into place, it should just fit into place naturally. .017 or .023 wire is easiest to use for butt welding. You will be literally welding into thin air SO you will be welding into the puddle, letting it flow into the panels. Start at the tack beads and make the puddle flow. Practice, practice, practice : up, down and sideways to get the feel for it. Let the welds cool naturally, DO NOT air quench or water quench, that's called shrinking for a reason. Quenching WILL warp your panels. Have fun with it, once you learn it you'll know it for life. |
Can you "control" metal movement by carefully cooling, yes. HOWEVER, this takes a LOT of experience. The simple basics is, cool hot metal, shrink, warp, BAD, no-no. But on the gap, this is an opinion, personally, ZERO gap is best according to every tin man I know. I weld butt welds (I am miles from a "tin man") with ZERO gap. I have a book where the guy even measures the metal before and after welding and the larger the gap the more shrinkage occurred. But again, depending on how it is welded it could make a big difference or little with or without a gap. It is largely preference. I personally don't like the butt weld clamps, just don't. I use large vice grip C clamps ( I have a couple of two foot deep ones). The magnets sound like an interesting idea. I have heard it many times but forget and never try it. Brian |
"You said a mouth-full, ESPECIALLY about cooling the welds. This is without a doubt one of the biggest, if not THE biggest urban myths of autobody. Cooling hot metal causes it to SHRINK. Shrinking causes warped panels, PERIOD, end of discussion."
Thank you Brian, it's evil twin is "Hammer Welding": 1) sheet metal is a 3 dimensional object, it has CUBIC volume. If you hammer down the weld the metal must go somewhere, that's called stretching the metal, making an oil can that's a bear to remove. 2) with steel, if it has cooled below cherry red but still too hot to touch, hammering will induce stress fractures, (metal fatigue, work hardened). If the welds need to be hammered, wait until it's room temp. Yes, bodymen have always had a warped sense of humor. |
| Confessions of an autobody shop owner. How to pick a shop to have your car restored. | MARTINSR | Hotrodders' Lounge | 27 | 01-29-2010 02:22 PM |
| Brazing body panels? | SteveU | Body - Exterior | 10 | 09-01-2008 09:41 AM |
| hello first time doing body resto,questions | YJ 383 | Body - Exterior | 8 | 12-29-2006 07:32 PM |
| Cutting doors open on race body | Mike Britton | Interior | 10 | 10-29-2006 03:36 PM |
| Brazing body patch panels? | rlackey | Body - Exterior | 5 | 03-04-2005 01:05 AM |
