Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cutting and using an old steering column?
Old 01-24-2013, 10:55 AM
timothale timothale is offline
Wiki Edits: 27
connectors
If you use a U joint or coupling, you should tighten the allen screw to make a mark on the shaft then drill a recess for the screw point, then double nut and locktite. After I had road tested everything I tig welded it.
