cutting windshield - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-22-2012, 07:46 PM
Well I got the glass cut without breaking it, but as you can guess its a long way from fitting correctly. Nothing a little metal work won't fix. That's why you cut the glass first. LOL! Brian its ok to say I told you so. You live and learn from your mistakes. If you don't try you don't learn anything. This is why I wanted to fit the glass before I finished all the metal work, so I could adjust if needed.
  #32 (permalink)
Old 04-22-2012, 07:53 PM
Wow. Pictures! Pictures! Pictures! Congratulations. Anyone who cuts their fist curved windshield on the first try has something to brag about.
  #33 (permalink)
Old 04-22-2012, 09:03 PM
It was really easy with a siphon sandblaster cutting the outside first. You just go slow . I made about 3 passes then went down to the plastic. Flipped around and did the same thing on the inside. Then got the old beltsander and smoothed the edges. Took about 4 hours, but I did it myself and didn't have to pay someone else to do it. Not that I'm opposed to paying,but it does feel good to do it yourself.
Al
  #34 (permalink)
Old 04-22-2012, 09:06 PM
  #35 (permalink)
Old 04-22-2012, 09:20 PM
WAIT A MINUTE HERE! You cut the friggin glass without breaking it?? Forget me saying I told you so! You TOLD ME SO with the glass, you cut the friggin glass without breaking it? Photos, videos, show me the good stuff!
  #36 (permalink)
Old 04-24-2012, 07:02 PM
Well here you go. tell me what you think.
Al
Name:	camera shots 509.jpg
ID:	64949   Click image for larger version
Name:	camera shots 508.jpg
ID:	64950   Click image for larger version
Name:	camera shots 492.jpg
ID:	64951   Click image for larger version
Name:	camera shots 521.jpg
ID:	64952   Click image for larger version
Name:	camera shots 522.jpg
  #37 (permalink)
Old 04-24-2012, 09:32 PM
The pattern I made showed how the lower corners needed to be cut to lean the glass back. You can see by yours, that is exactly what needs to happen.
When this happened I need to add material to the lower corners right at the base of the A pillar because as it leaned back that bottom corner pulled away from the A pillar. But it went pretty smooth up at the top I don't remember much mods other than a little at each upper corner. The bottom is were most of the work went.
I am blown away that you pulled off cutting that glass. What kind of sand blaster?
  #38 (permalink)
Old 04-25-2012, 07:55 AM
Brian, it's just a cheapo craftsman siphon type loaded with black beauty. I believe I will try to cut the bottom corners first before any metal work begins. I'm just concerned cutting there will cause the glass to shrink from side to side, becoming narrower and causing more problems if you know what I mean. On a side note ,I'm concidering purchasing a shrinking disc any info you have on these would help. Are there any tutorials on is useage.
Thanks Al
  #39 (permalink)
Old 04-25-2012, 08:12 AM
Yes, that is exactly what happens and that is why you will need to modify the hole! That is the beach with the glass, you can't change it's shape like metal! It is very unforgiving. I wish I took photos like I do now back when I did it!
I do remember having to narrow the hole a little, when it was all done it worked out pretty good, you could hardly tell. I do remember looking at other trucks after I did that one and seeing once you look up close that they had done the same thing.
  #40 (permalink)
Old 04-25-2012, 08:37 AM
Wiki Edits: 27
shrinking disc
I saw one demo-ed at a car show several years ago. A guy watching ask if he could try it and was not sucessful so I kept my wallet in the pocket. A friend chopped his 49 merc and had one so I took another look. The principle is similar to using a torch. With a torch you heat a spot. it swells up, you use a hammer and dolly to flatten down the hump. The metal shrinks and pulls down the surrounding metal. A shrinking disc is the last step after you have used a hammer , dolly other tools to get the metal as close as possible. You need to have the paint removed. The spinning disc heats up the high spot, it tries to hump up more , you apply pressure to force the hump down then lightly raise the disc to allow the spinning disc to circulate air and cool it. There has been quite a bit of discussion on making and using a disc on the metal working sites such as metalmeet, metal shapers, allmetal and others. I used a stainless steel plumbing clean out cover on my 4 1/2 grinder, it worked but the larger ones sold for a large grinder will be faster.
  #41 (permalink)
Old 04-25-2012, 08:57 AM
I have to assume you posted this to the wrong thread, we are talking about glass here. The shrinking disc is an amazing tool, I don't know anything about the way you describe it's use. From what I was taught is you run the disc over the panel it hits only the high spots kinda like a "Heat block" and then you cool it with air just as you would shrinking with a torch or any other heat creating tool.
I have done little with mine, but what I have it worked out very well.
  #42 (permalink)
Old 04-25-2012, 09:03 AM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
this is a good un ! ive got a windshield to cut for a 63 nova. i mite feel better bout tryin it myself now !i have a cracked one to practice on.
  #43 (permalink)
Old 04-25-2012, 09:21 AM
Thanks Al
  #44 (permalink)
Old 04-30-2012, 05:15 PM
well i've got the glass fitted to the hole. It took cutting the glass a few more times. Like around the bottom corners and alittle at the top corners. Tim your tip with the gasket saved me from making some big mistakes. I was fitting to the wrong area of the hole. Now comes finishing the metal work. I have tacked the frame back together now fill in all the gaps, have the passenger side looking pretty good. will get pics soon.
  #45 (permalink)
Old 05-01-2012, 07:55 AM
Old Fool's Avatar
Thanks Al
Wray has just what you are wanting:
http://www.ebay.com/itm/COMBO-Shrink...item19cf5fbaed
The Following User Says Thank You to Old Fool For This Useful Post:
hotrodbarn (07-03-2013)
Windshield cutting idea to run by the forum JMSTOY Body - Exterior 21 02-16-2012 03:52 PM
Cutting and securing windshield molding hotwheels1 Body - Exterior 5 01-01-2011 08:55 AM
cutting windshield? Cape Cod Bob Body - Exterior 5 07-26-2007 06:37 AM
Cutting curved windshield swoodard23 Body - Exterior 16 08-05-2005 10:27 AM
windshield cutting after chopping the top nosliw721 Body - Exterior 6 12-22-2002 03:40 PM
