I need to replace a cv axle boot on my mom's car. Ive seen ones before that are split in middle. Are you supposed to glue those together with something or how do they work?
Only use a screw- or glue-together "split" boot if you are not removing the shaft. They should be considered a temporary fix- they do not last anywhere near as long as a 1-piece boot.
If the boot's been damaged long at all, all the grease will have been thrown out, dirt will have gotten in- and the joint is (or soon will be) history. Check to see if the grease feels gritty. If it does, replace the joint or shaft. If the shaft makes any noise (clicking on turns, clunking, etc.- removing and replacing it now would be the best bet, IMO.
If the boot just got damaged and wasn't driven any distance, a one-piece replacement boot is always better than any of the stop-gap split boots. But better still is to just replace the shaft and be done w/it.
i agree with cobalt.
the split boots don't last.
IMO, replacing a C/V boot is a waste of time. if im pulling the shaft because of a bad boot, i'll put in a remaned shaft.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
