We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 07-04-2009, 10:05 AM
mitmaks's Avatar
mitmaks mitmaks is offline
CV axle boots
I need to replace a cv axle boot on my mom's car. Ive seen ones before that are split in middle. Are you supposed to glue those together with something or how do they work?
Old 07-04-2009, 10:18 AM
cranky1's Avatar
cranky1 cranky1 is offline
Just stuck
Those came with with a bonding agent and ties to keep them together for the glue to set up....
Old 07-04-2009, 10:22 AM
mitmaks's Avatar
which ones should I go with? It would be easier to install glue-on ones but if theyre not perfectly glued they would leak grease.
Old 07-04-2009, 10:52 AM
cobalt327's Avatar
WFO
cobalt327's barnstar
Wiki editor
Last wiki edit: Chevrolet restoration packets
Wiki Edits: 20
Only use a screw- or glue-together "split" boot if you are not removing the shaft. They should be considered a temporary fix- they do not last anywhere near as long as a 1-piece boot.
If the boot's been damaged long at all, all the grease will have been thrown out, dirt will have gotten in- and the joint is (or soon will be) history. Check to see if the grease feels gritty. If it does, replace the joint or shaft. If the shaft makes any noise (clicking on turns, clunking, etc.- removing and replacing it now would be the best bet, IMO.
If the boot just got damaged and wasn't driven any distance, a one-piece replacement boot is always better than any of the stop-gap split boots. But better still is to just replace the shaft and be done w/it.
Old 07-04-2009, 04:48 PM
Soul_Hunter Soul_Hunter is offline
i agree with cobalt.
the split boots don't last.
IMO, replacing a C/V boot is a waste of time. if im pulling the shaft because of a bad boot, i'll put in a remaned shaft.
Old 07-04-2009, 06:51 PM
mitmaks's Avatar
I went ahead with whole boot, Ive removed old one and now Im stuck trying to remove outer cv joint
Old 07-05-2009, 06:53 PM
mitmaks's Avatar
Ended up replacing whole axle
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "CV axle boots"
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 07:50 PM
Remove Front CV Axle Rightytighty Suspension - Brakes - Steering 0 04-23-2007 12:27 AM
full size chevy truck cv axle install SSon18s Transmission - Rearend 3 04-10-2006 05:43 PM
CV Boots zeeman19 Suspension - Brakes - Steering 3 04-11-2004 12:20 PM
cv axle boots replace or buy new axle? catscan4free Transmission - Rearend 20 03-05-2004 08:25 PM
