i was told that my cv shaft is rubbing te crossmember on the rightside. before going out and taking the chance of getting ripped off i thought ide come ask you folks(as i usually do)a few questions. is this a major repair, or is it something i can take care of at home, with the aid of a cilton book. im no expert mechanic but i do have some mecanical skills. if you recommend i take it to a shop, what and what does this job intail. price wise, parts needed labor. its a 91 dodge dynasty 3.3 litre v6. i just want to go there knowledgabe so im not taken advantage of. once again, in advance thanks for your time and advice
I would first suspect engine/transmission mounts (or possibly cradle mounts) as the combination rides in a engine/suspension cradle . The engine may not be sitting level or weak mounts allow the engine to raise on acceleration and the shaft rubs something.
Possibly a bent/damaged strut (bad travel stops) would allow the strut to compress too far. Also check for bad control arm bushings/strut arm bushings that will allow the steering knucle to move forward/aft on acceleration/deacceleration.
Just make sure that it is not just simply rubbing on a plastic splash shield leaving a mark.
Hmm...Thinking again... ...Chrysler didn't use cradles, but it would still be a mount issue I believe.
thanks kultulz (cool name) ill get my book and go check it out. come to think of it i changed my timing chain not to long ago and i had to remove the engine mount. hmmm could be it. thanks so much
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
