Cylinder Bore Size - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2008, 05:12 PM
Cylinder Bore Size
I am building a 377 from a 76 SBC and today i measured the bores with an inside bore micrometer. I honed the bores last week and cleaned them all up real nice and then crosshatched them. When I measured the bores, they are still STD and they seem to be perfectly straight. I did not get any size fluctuations and the micrometer stayed tight in the bore and didnt snag as I went up and down each cylinder. So if these measurements are all right, am i good to just get a STD size kit? Just wondering what your guys opinions are.
Old 01-15-2008, 05:30 PM
SnottyAust's Avatar
GTS Monaro Coupe 406
If theres no ring ridge at the top of the bore ive done what you did with no probs but this has been for a work car.
In your case if your building some grunt and are using moly rings id take the block to a respected machinist for his evaluation.
If your buying forged pistons, most of these are made to order now for any bore size.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
Master Cylinder Bore Size W/Hydroboost? krehmkej Suspension - Brakes - Steering 17 03-04-2007 05:06 PM
.30 over cylinder bore? 350MC Engine 8 06-17-2004 02:08 PM
how to prepare a block blndweasel Engine 14 08-15-2003 12:28 PM
Cylinder size for 60 over bore chevy 350 BillyBanana Engine 3 07-27-2003 10:51 AM
