Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cylinder diameter VS. piston diameter
Old 01-28-2010, 10:04 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I highly doubt the Gen III/IV (LS) engines have an INTERFERENCE fit between the pistons and cylinders. The engine wouldn't run, especially when you account for thermal expansion.
The sleeves may be interference fit between with the block on aluminum engines but I doubt the pistons are interference fit with the sleeves/cylinder bores.
