Everything I have found indicates the modern LS Series have .0007 to .0018 piston to cylinder clearance (meaning the piston is .0007 to .0018 "smaller" just to be clear). I have done interference fit assembly before and I am currently a Machine Tool Work Inspector. A 4.00001" outside diameter object will not fit in a 4.00000" bore without force or changing the diameter of one or the other through thermal contraction/expansion.
I understand thermal expansion of the cylinder increasing the clearance BUT how do you get the engine cranked over and brought up to operating temps for the cylinder to expand at initial start up? One cylinder with the piston .0014" larger than the bore will be pretty tough to get moving when it's cold to say the least but think how tough that would be multiplied by 8. I'm not saying you're wrong, I'm not from Missouri and I'm not trying to be a butthead but I need a LOT more convincing on that one. If it's possible I'd be very interested in understanding how. |
Times 2 Hippie...
I'm not saying you're wrong, I'm not from Missouri and I'm not trying to be a butthead but I need a LOT more convincing on that one. If it's possible I'd be very interested in understanding how.[/QUOTE]
I concur, how would you even punch in the slugs? whats with Missouri hippie? just ask'n |
If you understand that pistons are barrel shaped(much smaller at the top than at the bottom of the skirt), and know just how and where the piston is touching the bore when cold, you can see how that fact and oil retaining skirt coating and piston skirt flex will allow this slight interference fit. Much(or all) of the interference fit is in the thickness of the coating, which is sacrificial. After the engine has run for a few minutes the coating is wore away and burnished to a perfect fit for the rest of the engine life.
Missouri is known down here as the "Show Me" state as the residents are hard to convince. It dates back to the early 1800's IIRC. If someone tells us something we question and we want proof we say "I'm from Missouri, show me."
Thats interesting and not doubting your knowledge/explination, but how do you actaully install the piston if its bigger than the bore squish it? or does it go in from the bottom? I am still think'n its bigger than the bore here,, school me/us
"rule of thumb"; 16 century expression, you could whip your wife but the stick could be no bigger round than your thumb... and here the piston can be no bigger round than the bore. |
The very bottoms of the skirts are small enough to fit into the bore(pistons barrel shaped, remember), it is the coating the makes most of the interference. |
OK so the coating must be 0.005 or so all the way round and it does actually squish down under some pressure, perfect fit, hmm LS1 magic,
I believe this is a moot point- no aftermarket piston manufacturer that I'm aware of is going to tell you to set the LS engine up w/an interference fit piston, as in the piston being larger than the bore.
IF there is a factory spec that allows for the piston to be larger than the bore- something that I personally highly doubt- it has got to be purely a factory deal, not anything that would ever be seen in practice outside of the OM. IMO, it makes zero sense to build an engine that tight. No amount of explanation will ever get me to say, yeah- that sounds like a good thing to do. But then I'm kind of set in my ways. And I'm not even from the "Show Me" state. |
yeah me neither, i'll let it go, just caught my attention and you know what they say about inquiring minds
| Help with continuing master cylinder problem | chris57 | Suspension - Brakes - Steering | 3 | 09-30-2003 02:35 PM |
| how to prepare a block | blndweasel | Engine | 14 | 08-15-2003 12:28 PM |
| Compression Ratio advice new vortecs | blndweasel | Engine | 8 | 06-11-2003 06:02 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
| Somebody stop me!!!! | Mrfixmaster | Suspension - Brakes - Steering | 35 | 01-29-2003 06:45 AM |
