cylinder head drain plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2012, 01:24 PM
Hi Guys
Does anyone know the thread size of the head drain plugs,they are smaller than the gm head plugs
thanks in advance
Old 08-19-2012, 02:21 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
"Smaller than GM head plugs...", you didn't tell us what heads these are.
Semper Fi
Old 08-19-2012, 02:25 PM
Hi, procomp heads(sorry couldn`t afford anything else) I would imagine the same as edelbrock heads possibly. The i.d with a vernier is .580 thou
Old 08-19-2012, 04:23 PM
SSedan64's Avatar
Sounds like 1/4 NPT/NationalPipeThread 18-TPI/ThreadsPerInch.
Info >> Dimensions - Pipe Threads
Old 08-19-2012, 07:56 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Those holes are for the temp sensor, not coolant drain plugs. The drain plugs are on the block underneath the heads.
Old 08-19-2012, 11:14 PM
Thanks for very helpful link,pipe threads are so confusing!
Old 08-20-2012, 02:32 AM
Pipe sizes are measured according to the inside diameter of the pipe(so proper flow can be calculated to achieve the desired flow), so the thread size will always be larger than the pipe size.
GM used at least 2 different size holes over the years, as mentioned above yours sound like they are 1/4 NPT
What is this drain plug ? 64Joker Engine 1 08-15-2012 02:05 PM
Where to put trans drain plug? kwacasey Transmission - Rearend 8 09-26-2010 06:50 AM
7/8-16 Oil Drain plug? Simplicity Engine 3 08-12-2009 06:55 AM
9" drain plug Javelin69 Transmission - Rearend 2 10-03-2007 08:00 PM
Aftermarket Drain Plug MI2600 Transmission - Rearend 12 08-15-2006 01:07 PM
