Cylinder Head Epoxy Filling - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2008, 07:27 PM
Doing some serious head porting and polishing on a set of 305 SBC 601 castings and need to know what type of filler/epoxy to use in the pockets where the rocker/guide plate studs protrude into the runners to smooth out the air flow.
I know many of you have done this but I have no idea how to/what epoxy product to use.
Thanks to all, this is a great site for all of us.
Roy
Old 11-23-2008, 10:17 AM
"Splash Zone" seems to be the product of choice for reshaping runners but If you dont have access to a flow bench you can only guess if the changes are helping or hurting airflow. As far as the stud holes in the runner go, this is common in alot of heads - even high end ones. If the stud pertrudes into the runner, (which I doubt it will) it should be trimmed. Use ARP thread sealer or equivalent on the studs during assembly. FWIW, I recently read the same question on another board and the consensus of some well respected builders was that due to the location of the hole, filling them showed little or no improvement in airflow.mudlust.
Old 11-24-2008, 06:42 AM
knuckle banger
Is 6cfm going to be worth the time and cost of the splash zone?
Old 11-24-2008, 10:24 AM
Last journal entry: PICTURE TEST
heads
IMO filling that hole is a total waste of time.
I doubt a 6cfm increase.
If you really feel the need to, RAM Racing in oxford PA has the best stuff i have ever used.
Do a web search for his site and you can buy it direct from him. Tell him Keith from K-Star Automotive sent you.
Keith
Old 11-24-2008, 03:28 PM
F-Bird, I'm curious about your results on the 416 head. I examined two sets of heads I have in the basement. The first set was a gm 624 casting with 1.94/1.5 valves -bone stock. The intake port has a large depression,(about 3/4") cast into the roof where the rocker stud was pressed in. The second set was an aftermarket aluminum head with a smooth (undimpled) roof. Drilling for screw-in studs broke through into the port roof leaving a 7/16 hole. Did the 416 heads have the big void as in the first example? What kind of flow numbers were you getting outta the 416's? Valve size? Test lift? Also, It has always been my understanding that Splash zone was gasoline resistant and only needed a top coat for alky use. Not trying to impugn your post - just curious.mudlust.
which small block chevy cylinder head? pds23 Engine 2 07-22-2008 07:19 AM
cylinder head CCs ? smokin63 Engine 1 04-25-2008 11:12 PM
Cylinder Head rebuild Kchart18 Engine 5 04-12-2006 12:54 PM
cylinder head cracked?!?!?!?! Blob Engine 4 01-24-2005 06:12 PM
cylinder head repair TIM LIMES Engine 6 07-16-2003 02:56 PM
