Cylinder head fixture for Drill Press - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2012, 03:13 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I have been modifying a couple heads here and there for screw in studs and larger springs and higher valve lifts. I was wondering if you guys have any good ideas on building a fixture that will allow me to do this on the drill press. I have been doing them with a variable speed corded drill and im just looking at a more efficient way to do these and also I can do it with a consistent speed and pressure if i do it with a drill press. Im looking at something that I can bolt to the table and fasten a head to it. 99.9% of what I do is SBC so I will build it for that.
Any ideas on what is available out there on the market for me to maybe purchase directly? I can make it but If I can find something like this already built for a reasonable price it will probably be worth it.
Thanks!
Old 11-09-2012, 04:14 PM
BWS BWS is offline
Won't comment on the appropriateness of DP's and headwork.........
But here's "probably" the fastest way to get started on fixturing.Starting with this and then snag a cpl right angle plates.
Atlas Craftsman 6" 618 101 Lathe Bed Model No 101 21200 | eBay
What's the Precision on a Drill Press? 71gtx Garage - Tools 15 07-26-2013 06:19 PM
Drill press clamping OneMoreTime Garage - Tools 9 03-28-2009 08:35 PM
Drill Press? djjc76 Garage - Tools 39 09-17-2007 01:31 AM
Bench Drill Press Theresa Shank Garage - Tools 14 02-11-2006 05:54 PM
Drill Press runout?? daimon1054 Garage - Tools 2 04-20-2005 05:12 PM
