mitchc,
Since all of your troubles are with the exhaust valves MAYBE the valve guide is sticking out into the exhaust air flow too much. If the guides are pressed in maybe they were driven in too far to begin with or maybe the retainer is hitting them in when the larger lift cam opens the valve? Just my thoughts. Good Luck Scholman |
This is a good example of why you can't just buy a set of heads and just bolt them on. I have seen serious issues with almost EVERYBODY'S "ready to bolt on" heads.
I have said it many times here. When you get some new or reworked heads from somebody you don't know personally, HAVE THEM CHECKED by a good machine shop with a good reputation. What it would cost you (I generally have to do a valve job and mill them, especially NEW aluminum head assemblies), you have probably aready spent in gaskets, materials, and machine work. You can't take anything for granted. Having said that, I would make sure the timing isn't retarded. That will make the exhaust valves run hot, making them stick in the guides. But a lot of the "big name" shops like to brag about how tight they make the valve-to-guide clearance (too damn tight in my opinon). THEN they use a positive valve seal on that too-tight of a guide. If the valve seals have a garter or tension spring on the top of the seal (making it tight on the valve, not the guide), it wouldn't be a bad idea to remove it from the exhaust seal. tom |
| SBC cylinder head bolts .. cast iron heads Vs Alum. heads | terror385 | Engine | 3 | 08-04-2006 08:34 PM |
| Cylinder Block and Head Material | Terry_Burtz | Engine | 1 | 05-20-2006 06:55 AM |
| Cylinder Head rebuild | Kchart18 | Engine | 5 | 04-12-2006 12:54 PM |
| cylinder head cracked?!?!?!?! | Blob | Engine | 4 | 01-24-2005 06:12 PM |
| Cylinder head help | Jeff Christenson | Engine | 3 | 03-08-2003 05:49 AM |
