Cylinder head ID? Anyone know what a head with a 5x stamp? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2012, 08:20 AM
Looking at an engine in a Buick but don't know if it's a Buick 307 or an Olds 350, the drivers side head has 5X stamped on it near the spark plug for the #1 cylinder. Any ideas what heads these are so I can try to figure out what engine I'm looking at?
Thanks for any help
Old 02-10-2012, 10:56 AM
Buick didnt make a 307. If its a buick V8, then the distributor would be at the front of the motor. The Olds engine will have the distributor at the rear.
Olds heads are marked in the spot you are describing, but would not use an X, maybe an A or a. If its an Olds motor, there will be a shelf right behind the water pump, but infront of the intake, that will have cast in numbers that will help you figure out what Olds motor it is. Also, later model Olds(1977 and up) will have the size cast into the side of the block.
Old 02-10-2012, 11:31 AM
I think you're right, I believe they're 5A heads, friend tells me its a good running engine but I may pass and just finish building my chevy 350.
Old 02-11-2012, 03:49 PM
Early to mid 80's 307. Very reliable motor, but youre not gonna get much power out of it unless you spend a lot of money. Build your Chevy, or find a bigger Olds(330-455)
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
SBC head stamp? OLDBLUE66 Engine 5 04-26-2008 09:59 AM
Cylinder Head Help mitchc Engine 2 07-08-2007 09:44 PM
cylinder head hp 81Blue Engine 9 11-14-2004 03:32 PM
sbc cylinder head chevystroker Engine 7 07-30-2004 12:40 PM
