Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cylinder Head Porting - INFO please.
Old 04-22-2011, 12:20 PM
Bad66 Bad66 is offline
Yeah he said it all. You can watch some vids on youtube also. JMO, if it's your first time I would stay away from the carbide burs. These badboys take alot of material off real quick (the pros use them to speed up the job). Porting is a much bigger job than most people think, and you can really mess up your heads if you haven't done your homework. Also, remember that any material you take out of the combustion bowl can affect your compression ratio. Good luck and have lot's of patience
