Cylinder head question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2005, 07:17 PM
Last journal entry: Future Plans
Well my 400 is now in the shop getting some work done and such and im wondering since im going to be using the stock heads for the time being. Im wondering if gasket matching and a 3 angle job would be worth while?
and how much power do you gain from that?
Old 02-20-2005, 07:29 PM
lluciano77's Avatar
Short changed on common sense
The 3 angle job may be worth it. If you plan on aftermarket heads later, gasket matching probably won;t be worth your time or money.
Watch out for cheapo replacement valves. I had a set of rebuilt 400 heads with replacement valves. The tip of the intake valve on my #1 cylinder broke at the keepers. It went crashing down into my brand new piston. Luckily it was so cheap it bent out of the way and got stuck where it didn't destroy the piston.
rookie sbc head question sfd771 Engine 9 02-08-2009 08:33 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
cylinder head cracked?!?!?!?! Blob Engine 4 01-24-2005 06:12 PM
Wicked SBC cylinder head Siggy_Freud Engine 4 01-06-2005 04:32 PM
New master cylinder question brian400ex Suspension - Brakes - Steering 5 03-08-2003 03:26 PM
