cylinder heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2009, 06:14 PM
i1964ss's Avatar
cylinder heads
hi guys, i've got a tech question. it's easy change cylinder heads on sbc without disturb timing or anything else
Old 10-04-2009, 06:25 PM
35pontiaccoupe's Avatar
Say that again? I think you're asking if it's possible to change cylinder heads without disturbing timing? If you don't already know the answer to that question you're probably better off having someone else change your heads!
I'm assuming you're talking about an older (non computer) sbc here.. In order to pull the heads, you have to remove the intake. In order to remove the intake, you have to remove the distributor, carb, throttle linkages, any accessories bolted to the heads etc. After removing all this, you're going to have to reset your timing, valve lash, etc.
If you decide to go ahead with this, get someone who has done it before or has built an engine at least. There are lots of good books on building engines that have all the info you need. You're basically taking the engine almost to short block so it's a pretty involved process.. Good luck!
Old 10-04-2009, 08:43 PM
diamond mike's Avatar
throw me under the bus agian
setting the timing is the least of your worries with this job, it just takes time, and maybe a freind whos done it before , watching and showing you the ropes
Old 10-06-2009, 06:53 PM
i1964ss's Avatar
cylinder heads
i'd know i've to take a lot of parts in order to change the cylinder heads is not like i'm completely blind about cars i can take apart and put it back together that's no big deal and is a 327 so there's no computer to mess with what i meant is there a way you can mark the distributor so you can put it back the same way, the heads have the valve job done already
Old 10-06-2009, 07:17 PM
S10 Racer's Avatar
http://www.warsprints.com
You need to turn the motor so #1 is at TDC. Remove the distributor cap and note where the rotor is pointing. You can make a mark on the distributor shaft flange where the clamp is and a matching mark on the intake so when you reinstall the distributor, you just line up the marks. This will be a waste of time if you are installing different heads as your timing will change depending on the cc of the heads and other factors.
Old 10-06-2009, 08:13 PM
i1964ss's Avatar
cylinder heads
appreciated thanks. and now that you mention, yes i will change regular heads for a double hump heads
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 10:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
Heads and Intake combo black66 Engine 4 07-23-2005 11:33 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
