cylinder heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2009, 10:24 AM
cylinder heads
o.k. I have two sets of sbc heads, one set is the 882's and the other set
is the 462624 that i was told came off a vette. Question, since they are both
1.94-1.5's are there any other differences? Mild build sbc.
Old 11-20-2009, 10:47 AM
DoubleVision's Avatar
The 882`s are smog heads, large inefficient combustion chambers.
The 624`s are smog heads just like the 882`s only they are lighter and known to be crack prone. Both heads make a good boat anchor and a better wheel chock.
Old 11-20-2009, 12:55 PM
ericnova72's Avatar
More for Less Racer
Neither are worth the money it takes to rebuild them, so onless they are in great shape, there not worth more than scrap iron price. You can buy new SR(stock replacement) aftermarket heads from Dart, RHS, and Engine Quest(EQ) for what a rebuild on these will cost, and the SR's are a better head in all respects - thicker, stronger iron, better ports.
Old 11-20-2009, 03:41 PM
BOBCRMAN@aol.com's Avatar
The 624's could have come off an 80's vette. But they are still junk. Lightweight castings. Most I see are cracked in the middle chambers.
The 882's are older heavier castings. These are also known for cracking. But of the two sets these are the better.
882's can be made better with minor port match on intake side.. Kind of the best of the worst!!
Old 11-20-2009, 04:37 PM
thanks for the tips. both sets are in really good shape. New question,
is there way for me to see if there are cracks in em' without taking
them to a pro? I'm so broke i can't even afford to pay attention....
Help with SBC Cylinder Heads! 66 chevy truck Engine 4 10-11-2006 11:05 AM
how much can I safely mill cylinder heads? Berliner Bel Air Engine 9 08-25-2006 09:51 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Most Practical Cylinder Heads for 383 build up. mouseman Engine 16 01-09-2005 09:58 AM
twin cylinder heads Terry411 Engine 4 09-17-2004 07:33 PM
