Cylinder Hone Preferences - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2013, 02:39 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Which type of cylinder hone do you prefer and why? I'm talking the ones you put in a drill, not the automatic ones.
1. Three stone type (Glaze breakers)
2. Ball/Flex hone
3. Others??
Old 03-06-2013, 03:03 PM
vinniekq2's Avatar
It depends on what you are honing. Difficult to use ball hone on wheel cylinders or calipers
Old 03-06-2013, 04:13 PM
BOBCRMAN@aol.com's Avatar
For engine cylinders, Ball or brush hone is only way to go.
But these are only for conditioning a good minimal wear cylinder.
Old 05-13-2013, 10:23 AM
64nailhead's Avatar
What grit is recommended? I'm changing pistons in a recently bored block (less than 5000 miles) - it still has cross hatching and no ridge. I checked for overbore and there less than .0005" anywhere in the bores (my bore measuring tool is accurate within .0003".)
Old 05-13-2013, 10:31 AM
Banned
hone has to match the rings, but yea for a DIY quick job a ball or brush is best though I have ran a 3 stone with out any problems.
Using a good lube and cleaning the bores is a very critical step as well.
Cylinder Hone Tools/Brushes ChevroletSS Garage - Tools 11 11-27-2012 08:46 PM
Bottle Brush Hone for 230 Six Cylinder? ctandc Garage - Tools 6 04-16-2012 08:22 PM
Radiator brand preferences? Motochris Hotrodding Basics 5 06-22-2011 05:39 PM
Piston Ring Preferences? dwashingt3 Engine 1 08-05-2009 05:01 AM
Cylinder Honing - Flex Hone Grit Number - Help leejoy Engine 12 01-25-2008 12:58 PM
