Cylinder honing tools
I am interested in purchasing a cylinder honing tool and the replacement stone grits.
I check on google and ebay for some Honing tools but there is not enough detailed information. I AM GOING TO USE THIS TOOL FOR: Single Cylinder Engines. A 5hp Briggs engine, a Honda Moped engine maybe down the road use it one some multiple cylinder engines. Piston sizes between 2in - 4in ( this is just an estimate) What I want to know: Should i get a 2 or 3 stone honing tool? Where can i buy one? I want to be able to purchase the replacement stones from the same store. I want to be able to purchase the Course, Medium and Fine grit stones from the same store. Because i am doing the crank case i am not interested in the brake hones. Also the Briggs motors are all Aluminum as well as the other engines i am doing. How long should it take me to hone each cylinder? |
You would probably do well with a hone like this. It uses std. Sunnen stones and works well whit the majority of sizes you are likely to encounter.
http://www.goodson.com/store/templat...7e905e719f386a If you need a hone for a smaller bore size,, consider the jr. hone. http://www.goodson.com/store/templat...7e905e719f386a Barry |
why is the price so expensive of these?
The ones i looked at were so much less expensive. Why is this unit so much more? whats so special about it? does it work with a portable drill? heres a few ex. of what i was looking at: http://www.shop.com/op/~K_D_Tools_KD...5?sourceid=298 http://cgi.ebay.com/ebaymotors/3-3-4...QQcmdZViewItem http://www.sears.com/sr/javasr/produ...id=00999298000 http://www.opentip.com/products/Pist...ve-548987.html these guys have it all: http://www.mytoolstore.com/kd/kdengi10.html |
IMO that KD is going to be hard to beat for the work you have described, I have used one for years on engines of different types but mostly for honing hydraulic cylinders. Stones can be found at many auto parts and thing is sturdy enough to last for a LONG time, mine sure has. :)
I got one years ago from a local parts store.
I've been getting replacement stones from AutoZone stores in different grits-they seem to work just fine for me. :pimp: |
Do the hones you have use a 3 shoe or 2? Do you think that the actual tool matters in terms of quality? I do have two engines to do so i dont mind spend the extra bucks, but i prefer NOT to. These are just home projects for fun. |
The KD in your first link is the one I am referring to. Use a 3 stone hone and yep quality does make a difference since pressure needs to be evenly distributed and the results of a stone or other part coming loose during operation can be disastrous to a bore.
You should be able to find that hone and replacement stones at most any large auto parts, I think even Auto Zone carries KD here. Lisle is another brand that is an excellent hone and like the KD it, and parts, can be found quite easily at Auto supply stores.
Well i went down to the auto zone.
I purchase the cylinder honing tool which comes with medium grit stones. I purchased the course grit stones. They didn't have the fine grit stones. Will i even need these? i have alot of honing to do, lets see what happens to the cylinder damage. Im going to host pictures tomorrow |
I would have went with the flexi stone. It produces a great cross hatch pattern.
BEFORE. Can u notice the scars in the cylinder?
http://img2.putfile.com/thumb/6/16013415149.jpg http://img2.putfile.com/thumb/6/16013415165.jpg one a side note what kind of valve spring compressor can i use to remove these springs and valves? http://img2.putfile.com/thumb/6/16013415117.jpg |
There is a special valve tool made just for that type engine....should be able to find them around most auto parts or small engine shops. Usually pretty cheap, at least the ones I used to use were. Haven't done a small engine in years though.
| All times are GMT -6. The time now is 08:35 PM. |
