Cylinder honing tools
I am interested in purchasing a cylinder honing tool and the replacement stone grits.
I check on google and ebay for some Honing tools but there is not enough detailed information. I AM GOING TO USE THIS TOOL FOR: Single Cylinder Engines. A 5hp Briggs engine, a Honda Moped engine maybe down the road use it one some multiple cylinder engines. Piston sizes between 2in - 4in ( this is just an estimate) What I want to know: Should i get a 2 or 3 stone honing tool? Where can i buy one? I want to be able to purchase the replacement stones from the same store. I want to be able to purchase the Course, Medium and Fine grit stones from the same store. Because i am doing the crank case i am not interested in the brake hones. Also the Briggs motors are all Aluminum as well as the other engines i am doing. How long should it take me to hone each cylinder? |
You would probably do well with a hone like this. It uses std. Sunnen stones and works well whit the majority of sizes you are likely to encounter.
http://www.goodson.com/store/templat...7e905e719f386a If you need a hone for a smaller bore size,, consider the jr. hone. http://www.goodson.com/store/templat...7e905e719f386a Barry Last edited by topfuel; 06-12-2007 at 04:25 PM. |
why is the price so expensive of these?
The ones i looked at were so much less expensive. Why is this unit so much more? whats so special about it? does it work with a portable drill? heres a few ex. of what i was looking at: http://www.shop.com/op/~K_D_Tools_KD...5?sourceid=298 http://cgi.ebay.com/ebaymotors/3-3-4...QQcmdZViewItem http://www.sears.com/sr/javasr/produ...id=00999298000 http://www.opentip.com/products/Pist...ve-548987.html these guys have it all: http://www.mytoolstore.com/kd/kdengi10.html |
I got one years ago from a local parts store.
I've been getting replacement stones from AutoZone stores in different grits-they seem to work just fine for me.
Do the hones you have use a 3 shoe or 2? Do you think that the actual tool matters in terms of quality? I do have two engines to do so i dont mind spend the extra bucks, but i prefer NOT to. These are just home projects for fun. |
The KD in your first link is the one I am referring to. Use a 3 stone hone and yep quality does make a difference since pressure needs to be evenly distributed and the results of a stone or other part coming loose during operation can be disastrous to a bore.
You should be able to find that hone and replacement stones at most any large auto parts, I think even Auto Zone carries KD here. Lisle is another brand that is an excellent hone and like the KD it, and parts, can be found quite easily at Auto supply stores.
Well i went down to the auto zone.
I purchase the cylinder honing tool which comes with medium grit stones. I purchased the course grit stones. They didn't have the fine grit stones. Will i even need these? i have alot of honing to do, lets see what happens to the cylinder damage. Im going to host pictures tomorrow |
Sure enough when I left the place I noticed in the short blocks they had sitting there for sale that EVERY one of them had these cylinder marks! I am not sure what they used to hone these engines with and these marks could actually be felt but even if you can not feel them they should not be there, there simply is no reason to do it. On a Ford 300 six some years ago the same thing happened and when I complained that time I was told "Aw don't worry about it they will fill up with oil and be ok"
There is a special valve tool made just for that type engine....should be able to find them around most auto parts or small engine shops. Usually pretty cheap, at least the ones I used to use were. Haven't done a small engine in years though.
| Recent Garage - Tools posts with photos |
| Where to start: Tools | Madd Syntst | Hotrodding Basics | 12 | 10-04-2009 03:50 AM |
| Hotrodders Knowledge Base: Garage - Tools | Jon | Garage - Tools | 0 | 11-26-2005 06:46 PM |
| Cylinder honing | Hawk51 | Engine | 12 | 01-14-2004 07:23 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
| Bleeding Wheel cylinder on a 91 corolla | ramvrao | Suspension - Brakes - Steering | 1 | 03-20-2003 03:38 PM |
