look down into the plug....
see its not dirty or has a broken or bent pin...pull on the wires to see if one is loose...could be a bad plug if you already changed the injector the only thing left is the plug or the coil...did you change out the coil to eliminate that?
Tazz
Rat Rods Rule!
