rule out the coil pack by switching the wire with the other wire on that pack. Meaning each pack fires 2 cylinders, It is not uncommon to see a weak side of the coil pack. If it does move to the other cylinder it most likely is the coil packor the plug wire, if it does not move then it is in the wiring for the pulse of the injector.
