Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cylinder Misfire
Old 02-03-2005, 10:47 PM
IcU812 IcU812 is offline
There's a condition called "fretting" with the injector connections. It's corrosion that takes place between the connector terminals and the injector terminals. Usually if you disconnect the connector and reconnect it, the problem goes away for a while, then comes back weeks later. The easy fix is to coat the terminals with dielectric grease and reinstall. This also works on coil terminals ( secondary side) and module connectors.
