Originally Posted by automotive breath
Two more things to consider; intake valve closing point and cranking RPM. Close
the valve sooner and pressure goes up; same goes for spinning the engine faster.
AGREE. Cam timing makes a big difference.
It is difficult to draw generalities about static compression vs. cranking pressures due to cam timing.
A little quad-four 95 Pontiac cranks at 225 and runs on cheap gas. (why?)
I've seen some late model Chevys that crank 160.
Saying that 175 is runable on 87 octane
and that 200 is about the limit for 93 octane
are both good generalities.
Special tweaks and exotic tricks can extend this somewhat.
