cylinder pressure on freshly rebuilt motor
I finally got myself a compression tester kit so I can measure cylinder pressure on my engines. I have a newly rebuilt motor with about 15-20 miles on it. 355ci with 5cc flat top pistons. Should be around 10:1 with the vortec heads. The motor still smokes like crazy. How long should it take for the cast rings to set? Cam is a howards 180325-08. Also what would be an appropriate reading on the compression test kit.
I've never had a new rebuild that smoked after two or three minutes of startup, if your cylinders were prepped properly, it should have seated the rings by now. What rings did you use, iron, etc? Different rings require different hone patterns. You might also have valve stem seal problems, were the heads redone? Did you have any difficulties installing the pistons, possibly breaking a ring? Sure they weren't installed upside down? What did you file the end gaps to or what were they when you fitted them?
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Im still curious about the 120psi reading I got. This seems rather low even for a fresh rebuild. Any ideas what I should be seeing. SCR should be around 10.25:1 and DCR should be around 8.19:1... im not 100% sure about DCR because my cam card got a wet spot right where Intake closing point is so it looks like 50.5 but im not 100% sure. |
If the cylinders are not round, just honing and fresh rings may never seal well unless there was little wear on the engine to begin with. Was it bored just before the chrome rings were installed?
Did you put the rings in out of the box or did you put square them in the bore and file fit them to the correct gap.
I had a 396 once that someone rebuilt and just put the rings in without checking them. They were 20 over in a 30 over bore. |
personally i would be more inclined to point the finger at your valve seals only because i had a 383 i built that leaked oil down the valves and during high vacume would suck oil off the valves and into the cylinder causing it to smoke when i started it an hammered down, really anytime it drew alot of air. idk about the vortech heads and how they seal the valves but sometimes with o ring seals they can be roled or pinched enough to leak. just my 2 cents...
The little o rings will not work very well unless the valve guides are 100%
and the oil shield is installed too. Even then it is normal for such a engine to puff a bit of blue smoke on start up as some oil does migrate down the valve guide. This was normal and acceptable back in the day before emissions laws. The oem GM vortec valve seals do a much better job. I would get a set and install them on your vortec heads. The piston rings will seat best by making controlled full power WOT runs. They will not seat by babying the motor. As stated there is a possibility you got the wrong rings or installed them upside down or in the wrong groove. Cranking cylinder pressure should be in the 150-180 PSI range. 120 is low. Valve/valve seat seal is another source of low compression readings. Last edited by F-BIRD'88; 03-25-2012 at 05:13 PM. |
Thank you for all the replies everyone! I guess I need to figure out my next step. I would like to maybe do a cylinder leak down test to find out if its the rings our heads. Can anyone post a link on instructions on how to do a proper leak down test. I will probably do valve seals next weekend. I have a set kicking around somewhere.
good deal, and good luch with this. just a little tip that might make it easier for you when you change the valve seals, i have herd rumor but never seen a tool that is basically a spark plug that plugs into your motor and has a chuck for your air compressor, basically it puts pressure into your cylinder and holds the valves up while you remove the springs, obviously you need the spring pullers that grab the spring but it might save you some time if you dont want to pull the heads, i have also herd of ppl sticking a screwdriver into the spark plug hole just so they dont fall all the way down after moving that cylinder to tdc
Agreed on the rings possibly butting if it overheated for whatever reason. KB will tell you they can butt- even w/0.060" end gap- if overheated. Using the small o-ring valve stem seals requires the steel oil shield to be used. X2 on using positive stem seals. |
| having trouble with freshly rebuilt 350 | 4x4chevy35s | General Rodding Tech | 10 | 04-27-2011 12:09 AM |
| Rebuilt 350 oil pressure woes... | jb88ci | Engine | 9 | 04-22-2011 11:38 AM |
| What fluid to use on a freshly rebuilt T-400 | Rufus_2 | Transmission - Rearend | 6 | 12-27-2009 10:59 PM |
| Freshly Rebuilt sbc 355 cranks over hard | awoodman | Engine | 8 | 02-09-2009 06:52 PM |
| Carbon Buildup in freshly rebuilt heads? | Chevy21 | Engine | 1 | 11-08-2004 03:23 PM |
