Hey,
I don't post here much at all, but I frequently lurk around searching for info.
I recently picked up an early 350 block that was cleaned up, decked and bored .030 over by the previous owner some 10 years ago. It sat in a warehouse since, slowly eating itself away.
So he doesn't remember exactly what was done, but it was clearly cleaned & machined, and a quick check with my calipers shows a 4.030" bore.
Since it was sitting in an uncontrolled environment for SO long, the surfaces started to rust and pit. I cleaned it up with some lube and scotchbrite pads, but some of it is bad. Please look at the following pics and let me know what you think.
http://picasaweb.google.com/Michael.G.Hartman/1967ChevyCamaro
Please pardon the messy garage!!
Should I send it to a machine shop for evaluation? Do you think honing will clean it up. I can borrow one if it will work? Or would opening to .040 or .060 be the better route??
A machinist friend of mind also insisted that each bore had to have been machined with a SPECIFIC piston in mind/in hand. Since I just have the block and no pistons, it should be re-machined or spec matched to whichever pistons I eventually purchase.
I'm an engineer by trade but a total newbie to engine design and building.
I'm also planning on chasing all the thread and going at all the passages with a wire brush, smoothening the oil return holes and slapping a coat of hemi orange on it. Maybe even some of that insulation paint under the timing cover and intake 'valley'.
Thanks,
Mike
Thanks,
Mike
