leejoy,
The reason I have is, the cylinder had a deep rust area that would not clean up with the .060 over bore so they put the sleeve in that cylinder to save the block. Please don't think all machinists are "out to get your money". Scholman |
You are correct, most likely a cracked cylinder, but a properly installed sleeve is as good or better than any other cylinder.
Exactly, Great when properly installed. My cousin runs a 454 with 2 sleeves in his 68 camaro back halved race car. It runs 9.50s and has had the sleeves in it for about 6 years.So if it is not causing a problem it was probably installed right and never will.
there are many reasons for a sleeve..most of which would have nothing to do with the engine builders ability. core shift in the block is common on 454 Chevy blocks . sleeving is also a great way to save a rare engine from the scrap pile.i would not hesitate to run a sleeved block if the sleeve was installed properly.
sleeve 454
I think this probably adds to the reasoning why everyone before was telling you to have the block MAGGED. You may have to do that for sure now, and possibly pressure tested, to be sure that the sleeve is'nt the source of your water leak. As far as sleeves go, there are many reasons to use them, and many blocks are saved from the scrap pile by sleeving. My small journal 327 has a sleeve, the result of a broken ring that wore a vertical groove in a cylinder too deep to overbore out; had that cylinder sleeved, then rebored to the same piston that was not damaged (?), and it's been fine. At the time I could'nt find another small journal 327 block for a replacement because I did'nt like the idea of a sleeve ,but my machinist assured me it was done all the time, and that that cylinder would in fact be stronger than the others.
good information guys, thanks. I learned a lot from that.
The block is at the shop right now. Tony (the owner) over there will pressure test it next week and check for leaks. I'm keeping my fingers crossed here big time. If the block leaks at that #8 cylinder where the sleeve is then I am probalby screwed for some major $$$ and the block may have to get junked. I am anxiously awaiting his call and hopefully he will tell me the block does not leak under a pressure test and we can move forward from here. Lee |
Had a 366 truck block awhile back that decided to explode a piston in #7 and destroyed the cylinder walls but did not hurt the block itself... Simple install of a sleeve and rebuild put it back into service in a week... (was a bucket truck that was very needed)
Machinest told me the max amount of sleeves he would put in a block was 4 with max of 2 on each side otherwise the block would become to weak...? Myself I would not have more than 2 period otherwise just look for another block... |
All aluminum block are sleeved. they are either cast in during casting or machined and pressed in. Many many in fact I believe most diesel blocks are sleeved. Top Fuel funny car/dragster aluminum block motors are all sleeved.
When properly installed, press in replacement cylinder sleeves do not leak. |
Nothing wrong with a sleeve. If done right they are as good or better. Also, rest assured that on a block as common as a 454, they wouldn't waste money sleeving a useless block. It would be cheaper to get a different block and avoid the headache.
My guess is that maybe a piston went that scored that bore, or maybe a blown head gasket scored it and/or rusted it. |
| SBC cylinder head bolts .. cast iron heads Vs Alum. heads | terror385 | Engine | 3 | 08-04-2006 08:34 PM |
| 454 Chevy Block | truckmania | Engine | 1 | 04-07-2003 06:22 PM |
| Big Block cylinder heads | boss454 | Engine | 1 | 03-31-2003 04:30 PM |
| big block 454 | slip | Engine | 4 | 03-10-2003 10:47 PM |
| 454 Truck block different than Car Blocks? | zachscc | Engine | 11 | 12-19-2002 01:27 PM |
