cylinders 3 & 7 dead - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 03:05 PM
Hi, ford flat head problem. 42 ford newly overhauled engine while running makes thumping type noise runs rough fire at all cylinders, compression at all cylinders cyl 3&7 are not working. pull sparkplug wire on each while running does not effect running act as if both cyl are dead. pulled heads and valves seem to be functioning going to re-check valve adjustment. ignition has been up graded to pertronix . did have to re adjust valves after receiving engine from builder not adjusted right by the builder. before adjusting valves had no compression except 3&7 cylinder after adjustmanet all cyl have 120 compression. just don't run right with the noise and the dead cylinders 3&7. what do i lool for next?
Old 04-21-2013, 04:30 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
3 and 7 have the spark plug wires crossed? Just a thought
Fact is stranger than Fiction
Old 04-22-2013, 03:23 PM
if you beat my boat, well race
what kind of intake and carbs? possiable there not getting any fuel?
Old 04-23-2013, 11:53 AM
1badLemans's Avatar
If there is no compression in a cylinder it can lead to 2 issues.
1- valves not opening. Which leads go a bad cam lobe, bent valve, or bad spring.
2-broken piston rings
Old 04-23-2013, 02:35 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Add valves not closing, blown head gasket.
Semper Fi
Help 3 dead cylinders on my 305~_~!! 74chevyflat Engine 3 05-21-2007 12:56 PM
battery keeps going dead, i need some f#*%&!g help 406 ss monte Engine 21 10-12-2006 03:43 PM
2 Dead Cylinders.... Unkie Engine 5 08-23-2006 09:22 PM
Olds 350 help, 2 dead cylinders & cam lift Q? 360Camaro Engine 35 07-10-2005 02:42 PM
Dead cylinders HARVICKx29 Engine 13 12-07-2003 11:02 PM
