Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The D.O.T. gonna gitcha.
Old 11-27-2005, 08:23 PM
KULTULZ KULTULZ is offline
aka Duke of URL
There is a glitch in the Regulations ( -FEDERAL MOTOR CARRIERS SAFETY REGULATIONS- ).
While a motor vehicle (and combinations) can be defined as a CMV at or above 10,001 lbs., it is not required (in most cases) to possess a CDL unless the vehicle has a GVW of 26,001 or more lbs.
While you may not have to possess a CDL to operate the vehicle, you will have to register the vehicle with the FMCSA and usually home state domicile and comply with certain regulations.
Now if you can prove that the vehicle is not used for a money-making business (hobby class or maybe transporting personal vehicle), it is also not considered a CMV.
And while here, a motor home (regardless of size) is not a CMV. It is designed for personal use.
Please consult with a transportation lawyer for the fine print...
Pertinent excerpts from the regulations;
§390.5 Definitions.
Unless specifically defined elsewhere, in this subchapter:
Commercial motor vehicle means any self-propelled or towed motor vehicle used on a highway in interstate commerce to transport passengers or property when the vehicle—
(1) Has a gross vehicle weight rating or gross combination weight rating, or gross vehicle weight or gross combination weight, of 4,536 kg (10,001 pounds) or more, whichever is greater;
Gross vehicle weight rating (GVWR) means the value specified by the manufacturer as the loaded weight of a single motor vehicle.
Gross combination weight rating (GCWR) means the value specified by the manufacturer as the loaded weight of a combination (articulated) motor vehicle. In the absence of a value specified by the manufacturer, GCWR will be determined by adding the GVWR of the power unit and the total weight of the towed unit and any load thereon.
Motor carrier means a for hire motor carrier or a private motor carrier. The term includes a motor carrier's agents, officers and representatives as well as employees responsible for hiring, supervising, training, assigning, or dispatching of drivers and employees concerned with the installation, inspection, and maintenance of motor vehicle equipment and/or accessories. For purposes of subchapter B, this definition includes the terms employer and exempt motor carrier.
Private motor carrier means a person who provides transportation of property or passengers, by commercial motor vehicle, and is not a for-hire motor carrier.
§390.5 Definitions (Regulatory Guidance)
Question 3: If a vehicle's GVWR plate and/or VIN number are missing but its actual gross weight is 10,001 pounds or more, may an enforcement officer use the latter instead of GVWR to determine the applicability of the FMCSRs?
Guidance: Yes. The only apparent reason to remove the manufacturer's GVWR plate or VIN number is to make it impossible for roadside enforcement officers to determine the applicability of the FMCSRs, which have a GVWR threshold of 10,001 pounds. In order to frustrate willful evasion of safety regulations, an officer may therefore presume that a vehicle which does not have a manufacturer's GVWR plate and/or does not have a VIN number has a GVWR of 10,001 pounds or more if: (1) It has a size and configuration normally associated with vehicles that have a GVWR of 10,001 pounds or more; and (2) It has an actual gross weight of 10,001 pounds or more.
A motor carrier or driver may rebut the presumption by providing the enforcement officer the GVWR plate, the VIN number or other information of comparable reliability which demonstrates, or allows the officer to determine, that the GVWR of the vehicle is below the jurisdictional weight threshold.
Question 4: If a vehicle with a manufacturer's GVWR of less than 10,001 pounds has been structurally modified to carry a heavier load, may an enforcement officer use the higher actual gross weight of the vehicle, instead of the GVWR, to determine the applicability of the FMCSRs?
Guidance: Yes. The motor carrier's intent to increase the weight rating is shown by the structural modifications. When the vehicle is used to perform functions normally performed by a vehicle with a higher GVWR, §390.33 allows an enforcement officer to treat the actual gross weight as the GVWR of the modified vehicle.
Question 5: A driver used by a motor carrier operates a CMV to and from his/her residence out of State. Is this considered interstate commerce?
Guidance: If the driver is operating a CMV at the direction of the motor carrier, it is considered interstate commerce and is subject to the FMCSRs. If the motor carrier is allowing the driver to use the vehicle for private personal transportation, such transportation is not subject to the FMCSRs.
§383.3 Applicability.
(a) The rules in this part apply to every person who operates a commercial motor vehicle (CMV) in interstate, foreign, or intrastate commerce, to all employers of such persons, and to all States
§383.5 Definitions.
As used in this part:
Commerce means (a) any trade, traffic or transportation within the jurisdiction of the United States between a place in a State and a place outside of such State, including a place outside of the United States and (b) trade, traffic, and transportation in the United States which affects any trade, traffic, and transportation described in paragraph (a) of this definition.
Commercial driver's license (CDL) means a license issued by a State or other jurisdiction, in accordance with the standards contained in 49 CFR Part 383, to an individual which authorizes the individual to operate a class of a commercial motor vehicle.
Commercial motor vehicle (CMV) means a motor vehicle or combination of motor vehicles used in commerce to transport passengers or property if the motor vehicle-
(a) Has a gross combination weight rating of 11,794 kilograms or more (26,001 pounds or more) inclusive of a towed unit(s) with a gross vehicle weight rating of more than 4,536 kilograms (10,000 pounds); or
(b) Has a gross vehicle weight rating of 11,794 or more kilograms (26,001 pounds or more); or
(c) Is designed to transport 16 or more passengers, including the driver; or
(d) Is of any size and is used in the transportation of hazardous materials as defined in this section.
( GIGGLE GAS )
Gross combination weight rating (GCWR) means the value specified by the manufacturer as the loaded weight of a combination (articulated) vehicle. In the absence of a value specified by the manufacturer, GCWR will be determined by adding the GVWR of the power unit and the total weight of the towed unit and any load thereon.
Gross vehicle weight rating (GVWR) means the value specified by the manufacturer as the loaded weight of a single vehicle.
Hazardous materials means any material that has been designated as hazardous under 49 U.S.C. 5103 and is required to be placarded under subpart F of 49 CFR part 172 or any quantity of a material listed as a select agent or toxin in 42 CFR part 73.
Non-CMV means a motor vehicle or combination of motor vehicles not defined by the term "commercial motor vehicle (CMV)" in this section.
Out of service order means a declaration by an authorized enforcement officer of a Federal, State, Canadian, Mexican, or local jurisdiction that a driver, a commercial motor vehicle, or a motor carrier operation, is out of service pursuant to §§386.72, §392.5, §395.13, §396.9, or compatible laws, or the North American Uniform Out of Service Criteria.
§383.91 Commercial motor vehicle groups.
(a) Vehicle group descriptions. Each driver applicant must possess and be tested on his/her knowledge and skills, described in subpart G of this part, for the commercial motor vehicle group(s) for which he/she desires a CDL. The commercial motor vehicle groups are as follows:
(a)(1) Combination vehicle (Group A) — Any combination of vehicles with a gross combination weight rating (GCWR) of 11,794 kilograms or more (26,001 pounds or more) provided the GVWR of the vehicle(s) being towed is in excess of 4,536 kilograms (10,000 pounds).
(a)(2) Heavy Straight Vehicle (Group B) — Any single vehicle with a GVWR of 11,794 kilograms or more (26,001 pounds or more), or any such vehicle towing a vehicle not in excess of 4,536 kilograms (10,000 pounds) GVWR.
(a)(3) Small Vehicle (Group C) — Any single vehicle, or combination of vehicles, that meets neither the definition of Group A nor that of Group B as contained in this section, but that either is designed to transport 16 or more passengers including the driver, or is used in the transportation of materials found to be hazardous for the purposes of the Hazardous Materials Transportation Act and which require the motor vehicle to be placarded under the Hazardous Materials Regulations (49 CFR part 172, subpart F).
§383.91 Vehicle Groups (Regulatory Guidance)
Question 1: May a State expand a vehicle group to include vehicles that do not meet the Federal definition of the group?
Guidance: Yes, if:
a. A person who tests in a vehicle that does not meet the Federal standard for the Group(s) for which the issued CDL would otherwise be valid, is restricted to vehicles not meeting the Federal definition of such Group(s); and
b. The restriction is fully explained on the license.
Question 2: Is a driver of a combination vehicle with a GCWR of less than 26,001 pounds required to obtain a CDL even if the trailer GVWR is more than 10,000 pounds?
Guidance: No, because the GCWR is less than 26,001 pounds. The driver would need a CDL if the vehicle is transporting HM requiring the vehicle to be placarded or if it is designed to transport 16 or more persons.
Your mileage may vary.
PLEASE!
DO NOT stand there and tell Smokey he is full of it because KULTULZ said something different than what he is saying. If you drive a CMV even without the need for a CDL, you should make yourself aware of these regulations. Most DOT people are not that well versed in them or are trying to pull something.
