D A Sander - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 01:58 PM
daveh's Avatar
D A Sander
Hey Guys,
I am looking for a D A Sander. Any recommendations? What features should I look for? Not looking for the most expensive but one that is reasonable. I have an 80 gallon, 2 stage compressor. I am looking for one that works well and is compatible with my compressor. I am looking for one that I don't have to hunt all over for paper.
Also, how about the same question for a block sander.
Thanks
Dave
Old 03-22-2005, 07:10 PM
mrcleanr6's Avatar
holy crap man!!! you are still searching for the sander. last 2 times we went through this, if i remember right, you were asking about both the compressor and the sander. i see you got the compressor. what brand did you finally decide on? as for the sander i think just about everyone recommended the dynabrade.
Old 03-22-2005, 07:17 PM
MadRabbit's Avatar
ya just need a bigger hammer
Try
www.harborfreight.com
I just looked at some stuff there and they have a good DA on sale for $49.99!
this link is dirrectly to that DA http://www.harborfreight.com/cpi/ctaf/Category.taf?CategoryID=322&pricetype=
Old 03-22-2005, 07:23 PM
rick458's Avatar
Wookie
Northern carries 6" sticky disc in a 50 pc roll box
in many grit sizes I have used about 30 discs
getting ready for priming
Old 03-22-2005, 09:09 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
If you plan on using the DA for a long time,spend the money and get a Dynabrade. I used a HF one and it's a fair unit but the guy I did the 69 for gave me one from his cabinet shop that was ancient and I'm still sanding it's butt of today. You can interchange pad's as well so 6" or 5" paper is no problem. It does sand better/faster as well.
As for the block sander,I assume you mean a jitterbug, I have one but it is not really of much use IMO. Blocking is best done by hand with different length/width blocks. Anything from wood,rubber, to the $$$ adjustable rod one's.
A straight line sander is nice for preliminary filler leveling but you wouldn't want to finish block with one.
A "cheese grater" body file is a MUST have for filler work before it hardens.
Old 03-22-2005, 11:17 PM
mrcleanr6's Avatar
not to get off topic but have you used one of the adjustable rod sanders?? if so, do they work pretty good? wanted to pick up one of the long ones but didn't know if it would make a big difference.
Old 03-23-2005, 07:53 AM
daveh's Avatar
Thanks guys I know, I know it takes me forever but when spending that kind of money I don't want to rush into anything. Thanks for all of your advise. I love this board you guys are always a big help.
Old 03-23-2005, 07:24 PM
Bee4Me's Avatar
mrcleaner6,
They are the *******
It's the best sanding tool since the DA. I just got one to check it out and they are amazing.
I used to use some 1/4" "peg-board" for contured areas as it is flexable and holds it's "flatness" but holding the proper shape for blocking was sort of an issue sometimes.
I just wish I'd thought of them.
Old 03-23-2005, 08:49 PM
Mrcleanr6,
Ive got the AFS sanders, got two sets of em. I LOVE the things!! I do production collision repair and those sanders are the only sanders I use anymore.
They really speed things up and IMO create a smoother flatter surface, well worth the price. The cheapest place Ive seen them is www.autobodystore.com ...Eric
As for DA sander dynabrade hands on. But on the other hand if you are wanting something for HEAVY stock removal its hard to beat a National Detroit DAQ or EZQ sander. They have a more aggresive pattern that removes material faster.
Old 03-24-2005, 06:21 AM
mrcleanr6's Avatar
hey guys, thanks!! i guess i'll have to break down a pick one up.
DA sander scratches in rear window rusty428cj Body - Exterior 2 02-15-2005 08:13 AM
Craftsman DA Sander & Sandblaster 70chevy Garage - Tools 10 12-28-2004 10:51 PM
Source of wet-or-dry for DA sander? willys36@aol.com Body - Exterior 3 12-15-2004 07:08 PM
Best sander for under 200.00? Pepsimayn Body - Exterior 13 12-02-2004 08:10 PM
Can i use an electric sander? leastbay Body - Exterior 1 07-17-2004 04:55 PM
