D1ve Big Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2008, 05:32 AM
D1ve Big Block
Hello Motor Heads,
I recently uncovered a time capusle that was pulled and set on an engine stand some 25-30 years ago.It is a carb to pan complete motor from a speed boat.
It was taged as a 429 Cj 375 horse. motor ( Valve coversticker.)
It is my understanding that the D1Ve was only offered as a Crate motor short block in either 429 or 460 depending on the crank pkg ordered.
Has anyone heard this as well?
Some guys call it a Lincoln Motor But is not what I have been told.
My information is a Special application Block sold as a Short Block only by Ford
Dealers. Also it is widly used for Nasscar etc and can be stroked to around 566 C I and is capable of 600 and more horse.
I have done quite a lot with Chevys over the years and am wondering if anyone out there would think it may be a good idea to oil the bore through the spark plug holes before diassembly? Have not tried to turn it over since the heads and plugs are in place yet.
Am wondering if this may be the aluminum piston model or not.
It is the Cast Intake Holly set up...DO0e9425-0 with a carb tag reading D4JLT 6F30 7971
Any information would sure help Guess I should see if it will turn over...
Thanks H F
Old 08-12-2008, 08:24 AM
onebadmerc's Avatar
I need a bucket of arc sparks
There is nothing special about a D1VE block, it is just your standard run of the mill 1970's 429-460 block. I have one in my 78 F250, one on my engine stand and one in my shed.
Old 08-12-2008, 08:42 AM
scottford351's Avatar
Yep, Its a garden variety block. nothing special.
The 429 Cobra Jet came standard issue with a quadrajet carb.
What is the casting numbers on the head? The CJ head is DOOE-R
Old 08-12-2008, 09:33 AM
this site's info may help you sort out what you do have....
http://429mustangcougarinfo.50megs.com/
if it is all "correct code dates" original parts, you may want to investigate selling it to a restorer....
Big Block 82 Pontiac Gran Prix william27103 Engine 3 03-30-2009 12:50 PM
Ford Big block 4 spd bellhousing bigblocktorino Transmission - Rearend 3 10-05-2006 03:56 AM
small block or big block southrncuz1816 Engine 16 03-19-2006 07:40 PM
Small Block Vs. Big Block bfrett123 Engine 3 10-14-2004 05:27 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
